Having a problem with slop/slippage on my cross-slide, enough that the toolpost bucks at the slightest pressure. The slippage is completely north-south, the filister bolt holding the cross-screw nut is tight, the gibs are cleaned and tight. At the handwheel there's about .015 slop and the whole handwheel to cross-slide screw seems a bit loose. If I lock down the carriage the entire cross=slide assembly will shift, perhaps 1/64". Mikey, who has been hugely helpful to this still-newbie, has recommended that I lock down the cross-slide to isolate the problem but I can't find anywhere how to do that.
Also, this is a problem that has come up recently, after I replaced the two compound swivel bolts. It did not happen before, but clearly, with those two bolts bent I had other problems. Doesn't seem as if those would be the problem since all they do is enable the compound to swivel.
Help please?
Many thanks,
Tim
Help please?
Many thanks,
Tim
