- Nov 8, 2011
- 1,678
I've only used?played with my power feed on my lathe once, last night I started turning a part that needed a fair amount of material removed width & diameter and tried to figure the power feed out to speed up the job & get smoother results, gave up and hand cranked everything.
Anybody care to talk me through using it properly so I don't break anything?
Can I engage/disengage/reverse the rotation of the screw while running? (lever on head stock by change gears)
I know the "Knob" on the apron is for the half nut for making threads and not used for power feed.
What is the function of the 3 place lever on the apron?
What is the function of the 2 place lever on the apron?
What is the function of the little geared wheel that you can engage into the lead screw? (has 4 #s on it)
I've had both feeds working but they seem kinda difficult to engage.
It's time for me to get serious here and start making some money
