Logan 820: what is this knob's purpose?
tmenyc
H-M Supporter - Gold Member
Oct 18, 2018
306
It's tailstock part LA263, called Knob, without descriptor. Under it is a closed-off vertical hole to fit the knob.
Thanks!
Tim
Ulma Doctor
Infinitely Curious
Feb 2, 2013
827
way back in the old days, there was a dauber in that position.
you would fill the cavity with read lead.
the red lead was used for lubrication purposes when working between centers.
you take a small dab of red lead and insert it into the center-drilled work ends, then place it between dead centers.
since we don't use many dead centers , the practice is fallen from favor
lead is carcinogenic, that too has been a reason for its demise
tmenyc
Oct 18, 2018
306
REALLY interesting. Thanks so much for the explanation!
Tim
wa5cab
Downloads Moderator
Staff member
H-M Platinum Supporter
Dec 25, 2011
7,771
What does the knob look like if you pull it out and look at the hidden end?
The Atlas machines of the period say to use white lead, which is a liquid or thin paste, with about the consistency of heavy cream. The widget that stores in a hole on the near-side top of the tailstock is called a dauber in the Atlas parts lists. I'm just curious as to whether what Logan called a knob is the original part that functions as what some other manufacturers called a dauber or just a hole plug because they weren't recommending white lead any longer but all of the tailstocks in inventory already had the hole.
HarryJM
Mar 16, 2015
186
I saw a video where someone made a little metal box with a dowel on the side or bottom of it to fit in that hole so now they have a little open storage platform.
Nogoingback
Oct 18, 2016
1,520
297802
It's a dauber, which is what the Logan parts list calls it.
tmenyc
Oct 18, 2018
306
My parts list just says "knob"! Now all I need to do is get some lead...
Tim
Razzle
Jul 22, 2013
6
Your lucky to have one. Most of them are gone. Mrpete222 on YouTube (tubelcain) suggests using cmd extreme pressure lube in the place of white lead. I found the cmd on Amazon for 10 bucks. It's a lifetime supply. You may be able to sell that piece on Ebay for 40 bucks ;-) I have never seen one in the wild before.
Sent from my SM-T510 using Tapatalk
tmenyc
Oct 18, 2018
306
Interesting. I'll keep it.
Tim
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
7,771
OK. So it is the dauber, even though called a knob.
tmenyc
Oct 18, 2018
306
I'll put a little cmd extreme pressure lube in there just before i use dead centers. Back then, didnt they say "A little daub will do it!" ?
Tim
Cooter Brown
863 Bronze
Nov 23, 2017
839
Shadon HKW has a great video about dead center lube.....
MrWhoopee
Jan 20, 2018
1,285
When I studied machine shop in the late 70s, those things were still in place and filled with white lead on the school's WWII vintage lathes. The instructor had squirreled away a 5 gal pail of white lead after it was banned.
lordbeezer
Sep 1, 2018
191
Ford motor company used to provide small container of white lead with replacement ring and pinion gear sets..in the 70's..have several somewhere..
AdBlock Detected
I've Disabled AdBlock
