Logan 820: what is this knob's purpose?
tmenyc
Oct 18, 2018
455
It's tailstock part LA263, called Knob, without descriptor. Under it is a closed-off vertical hole to fit the knob.
Thanks!
Tim
way back in the old days, there was a dauber in that position.
you would fill the cavity with read lead.
the red lead was used for lubrication purposes when working between centers.
you take a small dab of red lead and insert it into the center-drilled work ends, then place it between dead centers.
since we don't use many dead centers , the practice is fallen from favor
lead is carcinogenic, that too has been a reason for its demise
REALLY interesting. Thanks so much for the explanation!
Tim
What does the knob look like if you pull it out and look at the hidden end?
The Atlas machines of the period say to use white lead, which is a liquid or thin paste, with about the consistency of heavy cream. The widget that stores in a hole on the near-side top of the tailstock is called a dauber in the Atlas parts lists. I'm just curious as to whether what Logan called a knob is the original part that functions as what some other manufacturers called a dauber or just a hole plug because they weren't recommending white lead any longer but all of the tailstocks in inventory already had the hole.
I saw a video where someone made a little metal box with a dowel on the side or bottom of it to fit in that hole so now they have a little open storage platform.
My parts list just says "knob"! Now all I need to do is get some lead...
Tim
Your lucky to have one. Most of them are gone. Mrpete222 on YouTube (tubelcain) suggests using cmd extreme pressure lube in the place of white lead. I found the cmd on Amazon for 10 bucks. It's a lifetime supply. You may be able to sell that piece on Ebay for 40 bucks ;-) I have never seen one in the wild before.
Sent from my SM-T510 using Tapatalk
Interesting. I'll keep it.
Tim
OK. So it is the dauber, even though called a knob.
