I'm not familiar with the Logan but did u loosen the gib up? They can get adjusted to tight to run the threads out to the end. Or if u r trying to lift the compound out of the cross slide there should be a couple bolts or setscrews on the cross slide ,loosen those up at least 1/2" to allow the keepers to slide back out of the way as u pull the compound out.
I have the gib out, the outer half of the dial, and the handle off... it looks like the fixed side of the dial will have to come off to get the screw shaft out, but I don't see how it comes off...
