- Feb 13, 2012
- 60
I have a Logan 11" X 36" Lathe. I have never owned or operated a Lathe that I could not identify the taper of the headstock spindle. It does not match anything I have found.
The Outer diameter of the taper--inside the 1 1/2-8 threaded nose--- is 1.125 and the smaller dia. is 1" with a length of 2". The spindle through hole is 1.008.
I am beginning to believe that someone has made it a custom size, although it doesn't appear to be so.
Any information would be appreciated.
