[4]
Longer bed kit for Sherline lathe?
[3]
[10] Like what you see?
Bnystrom
Newbie
Jan 5, 2018
8
I have a Sherline 4530 and I need more capacity for longer projects. Does anyone sell a complete upgrade kit with a longer base, bed and lead screw? I didn't see anything on Sherline's site.
mikey
Dec 20, 2012
5,159
They sell the long bed and screw for the 4400 lathe. Give them a call. The beds are the same on the long and short bed versions other than length so everything should just bolt right on. Easy-peasy and cheap.
Bnystrom
Newbie
Jan 5, 2018
8
I've emailed them about it. I figured that everything other than the base, bed and lead screw would still work.
mikey
Dec 20, 2012
5,159
Yeah, forgot about the base.
mikey
Dec 20, 2012
5,159
Yeah, but for that you get the capacity. I could buy an entire long bed Sherline lathe for what it cost to buy a steady rest for my larger Emco lathe. Everything is relative, right?
Bnystrom
Newbie
Jan 5, 2018
8
True. I think I just found a line on an entire 4400 with a bunch of extra parts for less than the cost of the conversion parts from Sherline.
mikey
Dec 20, 2012
5,159
I would jump on it, B. Then you'll have both a long and short lathe. There are many times when having two lathes available will make a project possible. The long bed lathe is incredibly useful and allows you to make stuff that you wouldn't ordinarily think a Sherline lathe could make.
Bnystrom
Newbie
Jan 5, 2018
8
I picked it up last night for $300, which is about what the parts to upgrade my 4530 would have been. It's actually a custom industrial setup based on a 4400 and it took me a little while to figure out what I had. In addition to the stock lathe, it came with a 6520 dove tail headstock (that was apparently used as a tailstock) and a riser plate and pivot pin to raise the factory headstock to the same height. Both headstocks have spindles with a 9/16" ID and no Morse taper (Sherline p/n 40239). This should allow me to pass through stock as large as 14mm, which is a big plus. It also came with 2, 3-jaw chucks.
In order to use the tooling I have, I'm going to lower the headstock to the original height and use the standard tailstock. I can always change the configuration if I need to for a special project.
The cross feed table had been modified, so I'm going to replace it. I need a few small parts, but I'm going to end up with a second lathe with much improved capacity for relatively cheap money.
kvt
Oct 21, 2014
2,064
Sounds like a nice score. You can also get or make a riser if you have a QCTP, or you can get or make the higher set of tool post. I did that for mine. That way you can do a little bigger items as well.
Bnystrom
Newbie
Jan 5, 2018
8
The riser under the headstock is .435", which is between 11mm and 7/16". I have a couple of QCTPs, so making a matching riser seems like a great idea. I can use the dovetail headstock as a tailstock.
There's another option, too. I have the standard headstock riser block and QCTP riser block, but not the tailstock riser. Perhaps I'll get one and if it looks like I have a use for the dovetail headstock I can make a custom riser for it.
Lots to think about.
[6]
[5] [7]
