If your goal is speed you can always machine a backplate to attach a pullback chuck. A lever action draw bar is really fast, but a hand wheel draw bar isn't to bad, and its an order of magnitude cheaper. Its also easily machinable if you want to just make one. (The draw bar.)
If your goal is just repeatable and decent concentricity a good quality collet chuck mounted on a machined to fit back plate will likely cost less. Than a pullback chuck. Of course a 4 jaw chuck will accomplish the same thing at the expense of a little more setup time until you get more practice at dialing it in.
Another alternative (and I have done this) is to get a straight shank collet chuck, mount it in your 4 jaw, and dial it in. Then you only have to fumble with the 4 jaw once.
