• WTH HAPPENED TO H-M?
    After accidentally deleting a folder, we asked our web host for a backup. As nearly as we can figure, the 1/23 backup did not contain any attachments (over 250000 or avatars for our members). We then asked them for a backup to January 1, 2020, and THAT backup had no attachments or avatars, etc. Their backups were incomplete apparently, and overwrote our files with empty attachment files. We are very sorry for this. We are doing everything and anything we can to right this. HM
Looking for Sloan & Chace Collets
bearbon
Mar 21, 2013
26
The problem with my attraction to odd and unusual machines backfires when I try to find tooling and parts for them. I have a Sloan & Chace single-pedestal watchmaker's lathe with double cross slide and lever action tool indexing tailstock. This will be a great machine for making multiple copies of the same part - like a mini screw machine, but I need collets for it. The collet size is a 3SC (#3 Sloan & Chace). If I can't find any I'll have to modify the headstock spindle to accept WW collets or adapt a chuck.
Anyone have a few buckets of odd collets lying around?
Thanks, Bear
bearbon
Mar 21, 2013
26
Well judging by the lack of response to my post I gather no one is familiar with #3SC collets (or aren't interested), so I started looking into ways to adapt common collets to my Sloan lathe. Turns out it has the same 20 degree taper as a regular WW collet. The head lengths are a little different so the WW collets will be slightly recessed in the spindle but not by much. I'll make a new, longer draw tube to precisely fit the spindle ID and tap it .275 X 40 for the WW collets. The draw tube will keep the body of the collet centered in the spindle. I'm not making watches here so I think it will serve my purposes. I'll post pictures of the lathe when I get it all set up. It uses flat belts so that's something else I have to make.
You can see pictures of an identical lathe as mine at: http://www.lathes.co.uk/sloan&chace/
Scroll down the page to the first color photos of the single pedestal lathe with all the gadgets.
