- Sep 17, 2014
- 31
A couple decades ago I learned a bit of machining on my mentor's old South Bend lathe, not a lot, but some of the basics. A few years ago I picked up an old cheap Atlas 6" lathe & got it back into working shape. But before I could really start using it, we moved & I sold it rather than move it. So now we are finally settled in, I have a shop & the number of projects I keep realizing I need a lathe for are piling up. So I'm looking to get a lathe to help support my tinkering & puttering hobby. I do tractor work (operating my Kubota L4060 & keeping it & implements running) on the side. I have a bad habit of picking up cheaper old implements & trying to get them back online.
A lot of initial projects are going to be making bushings or just getting some stock & pins turned to fit, have some assorted low pressure plumbing type fitting sot make as well. Later projects are likely to be more precision projects. Might be some gunsmithing type stuff eventually. In my head that old South Bend is kind of my benchmark for size & all the projects I envision could have been done on South Bend, so I've always assumed I'd get something that size, probably old american iron. I actually don't know what size/model that SB was, guessing a 9, maybe a heavy 10, but it had a quick change gearbox.
I've been keeping an eye out for some good old american iron for a couple years, but haven't found anything. Not a lot here in Colorado compared to back east. I'm capable of checking machinery out & have done a ton of research (not quite memorized http://www.mermac.com/advicenew.html), but lack practical experience. With the time vs. money proposition as of late I'm probably just going to buy a new machine that will be up & running without a rebuild or other unknown suprises. My budget is $5k for a machine & enough tooling to get me going.
I'm probably going to be talking with Matt at PM about:
I may be able to find a better deal on some tooling, but am concerned about making sure stuff fits for now to get started. I'm sure I'll spend the next years or decades trolling Craigslist & auctions looking for deals once I re-familiarize myself with working on a lathe & more specifically whatever I end up getting.
Should I bother with the tooling from PM? Is it all carbide? From what I can gather in my research, I'll probably be best starting off grinding my own HSS. What size HSS should I be looking at? Any recommendations for a place to get some pre-ground HSS tooling to get started on day 1 & so I'd have something on-hand to copy rather than just all the YouTube videos I've seen?
Will probably pick up elsewhere online, unless PM has stuff in stock but not listed on their website:
Part of me wants to get a 3 phase machine right off the bat & VFD it, but It's a cost I can't justify yet. Would let me use the oscilloscope my wife got me for Christmas though...
A DRO is high on my accessories list, even though I could probably get by without it. I'm an IT guy at my day job & a nerd so inherently drawn to electronics. Plus I'm crap at math so any electronic aids to keep numbers straight are a very good thing. Any comments on the PM DRO vs. the Easson DRO?
Any suggestions on key stuff I'm missing from my plan & checklists? Might anybody be able to convince me to spend somebody elses money on a Taiwanese machine instead of the Chinese one? Any other thoughts or suggestions before I get around calling Matt at PM here in in a few days or before the end of the year would be appreciated.
- Lathe
- Cast stand
- Leveling feet
- DRO
- Drill chuck
- Boring/turning tool set
- Threading tool set
- Live center (looks to be included on the GT prefered package)
- Some HSS tool stock
- A gallon or 2 of hydraulic oil
- Way oil
- Digital calipers
- Dial gauge with mag mount
- Bench grinders (although I should probably get a better tool grinder, my current ones should get me started)
- 1-2-3 blocks
- Machinists level
- Drill bits (many of dubious quality or condition)
- Center drills
- Oil can
- Cutting fluid
- 4x6 bandsaw
- 500 gallons of diesel, as well as a few gallons of kerosene & a parts washer full of parts washer fluid
