• WTH HAPPENED TO H-M?
    After accidentally deleting a folder, we asked our web host for a backup. As nearly as we can figure, the 1/23 backup did not contain any attachments (over 250000 or avatars for our members). We then asked them for a backup to January 1, 2020, and THAT backup had no attachments or avatars, etc. Their backups were incomplete apparently, and overwrote our files with empty attachment files. We are very sorry for this. We are doing everything and anything we can to right this. HM
Lubrication of Watchmaker's Lathe Spindles
mckay3d
Apr 3, 2011
33
I have several older American Style watchmaker's lathes and want to make sure I use the best type of oil for lubrication of the spindles. All of these are plain bearing, hardened spindles. I use ISO 32 hydraulic oil in the Myford Super 7 spindle, but I think it might be too thick for the WW spindles. So... clock oil, 3-in 1, Nye watch oil, or... does anyone else have a suggestion? I have looked in all the books I have on watchmaker's lathes without success.
Maurice in Utah with dry spindles...
mckay3d
Apr 3, 2011
33
Well Duh! I just googled it and found this recommendation on the NAWCC forum: Spindle Oil ISO 22 (Mobil Velocite #10) - for speeds up to 3600 RPM,
Spindle Oil ISO 10 (Mobil Velocite #6) - for speeds over 6000 RPM
Sounds good to me.
maurice
core-oil
Dec 30, 2010
432
Hello Mckay3D I use spindle oil in my Boley & Leinen, No doubt you will have noticed these little lathes are greedy blighters where oil is considered, But I would rather stop on occasions, & give the little thing a drink, than find a main spindle seizing
cazclocker
Purveyor of cheese.
Sep 24, 2012
396
Sorry to sound in late, but I use Mobil Velocite #6 in my Rivett watchmaker's lathe, although I have used Mobil-1 synthetic motor oil for several years will NO bad effects. First I used 5-20W, then switched to 0-20W. The reason I switched to Velocite #6 is that it's specifically made for lathe spindles, and for me 3,400 RPM is the top speed - so #6 does quite well.
