- Feb 27, 2014
- 2,124
Yes, I depend on the indication. What I don't like is having to cycle through the different scales to get the one you want. Mach3 lets you (requires you to) set 10 jog increments. The pendent will cycle through them in one direction. I have it setup to repeat a sequence of 3 increments but that leaves one repeat to fill out for 10. Anyway I find myself regularly having to press the jog increment button several times to get the increment I want, when a rotary switch allows you to go right to what you want up or down. Also I find that when edge finding, I don't have to look at the pendent or the Mach3 display. I am looking at the edge finder. With the XHC I have to take my eyes off the work to look at the pendent display when I change increments (I always start at .1 and then as I get closer I decrements the increment until I am at .0002. Again not a huge deal but in a perfect world I could do this by feel on the pendent and not take my eyes off the work.
And yes, I am more than a little OCD over efficiency
