Machine Guarding
JimDawson
Global Moderator
Staff member
H-M Lifetime Diamond Member
Feb 8, 2014
11,138
As some of may know I'm building a small punch press for a customer. https://www.hobby-machinist.com/threads/servo-punch-press.72601/ This press is going to be out of my control and operated by unskilled or semi-skilled labor so it must be designed to be as safe as possible short of welding a large steel box around the entire unit and welding the main power switch in the Off position. :) In the die area there are no pinch points, completely finger safe. No reason to be poking around in there, but ya never know. :cautious: It will be guarded anyway with a lexan guard. And that guard will contact a limit switch that is in the E-stop circuit and must be in place to operate the machine. Designed to not be easily defeatable.
I had to add a stiffener to the press frame to keep it squared up, and in doing so created a pinch point at the wrist pin.
Without the stiffener installed
And with the stiffener in place. The bolt head moves up & down with the ram.
No problem, just build a lexan guard to cover the pocket.
But, this guard is WRONG. Mechanically it will work fine, the lexan is well suited for this application, and is completely finger safe. The guard allows easy access for removal of the wrist pin for die maintenance. Die maintenance would be done by skilled personnel, this is not an operator function. I have a fix for the problem and will implement it as the build continues, there are two solutions that I thought of.
But I wanted to post this to see if anybody else can point out the problems (there are more than one) with this design, it took me a day to realize that it wasn't right.
Time to put on your thinking caps. :eagerness: Looking forward to your comments.
If I'm seein it right it can't cycle down cuz the relief pocket is positioned wrong.......
You are correct in that regard, it needs another 0.125 clearance, but it is nearly at the maximum down stroke in the photo.
But that's not the problem, the problem is in the human factors.
I see no form of lubrication spots. Return spring?
Cheers
Martin
Cheers
Martin
Lubrication will be added later. Spring return is close if I understand correctly :)
The only issue here is the guard itself. I'll post the answers in a day or so if nobody else gets it. :)
It might be a safer guard if the mounting screws came in from the back side of the plate. Less chance for us dumb operators to take it off....
-frank
-frank
You're getting warm :)
For those of us that have a mechanical inclination and a rational thought process, it can be quite hard at times to think like an unskilled idiot, thus the need for beta testing to see how the mechanically impaired understands a simple process.
Just spitballin'.....since the cover is transparent, you will be able to see the wrist pin moving up and down, and to an unskilled operator this situation would indicate that something is loose or broken, triggering a brainstorm about investigating the situation by removing the guard.
Curiosity killed the cat....
If the machine will still operate with the guard removed, the hazard still exists. You need an interlock, either mechanical or electrical.
That's one of the issues. :clapping:Still at least one more that I thought of.
