Made a 14" table saw
Ed.
Aug 31, 2011
164
14" Table saw build.
Hi Guys, I needed a table saw so that I could slice and dice up some timber from the slabs I milled from 3 logs I had, this would enable the timber to dry out faster and give me an idea
of how much useable timber I ended up with. Had a 4HP 3 phase motor lying around in the shed and an old aquarium stand as well, so thought it was about time I did something with
them.
1. Made 2 bearing holders to fit 30mm ID bearings. Bored out some holes in some 80mm round bar, cut them off and welded them to some 10mm plate.
2. Welded a side plate at 90 degrees, these get bolted down to the frame and hold everything together.
3. Other side of the bearing holder.
4. Roughly turned a double pulley out of a larger round bar and turned down one end as that will be where the M10 grub screw locks down the shaft key. After it was cut, it was
drilled to size and then the pulley was welded to a piece of 40mm stainless rod. The lot was then machined to make it all true and remove any distortion made by the welding.
5. I put a thread on the end of the shaft to accept a threaded blade hub, but later on I had to remove that thread and made a new hub (Pic 8.) with straight through hole and a
larger flange. Having the thread on the end gave the blade a very slight wobble which at full revs would look normal till I started to cut some timber and then the blade would
oscillate dangerously, couldn't work out why till I connected up the VSD to it instead of directly to the power and dropped the speed down to 500 RPM and then I could just
barely see the wobble, at full revs the centrifugal force made it all look straight and hid the wobble until I started cutting. Probably from too much tolerance between the
male shaft thread and the female hub thread.
6. Shaft assembled (showing the old hub)
7. Making the new hub. Drilled some steel rod, welded it to some plate, cut the corners off and attached it to the shaft, put the whole lot in the lathe, used a steady rest on
the bearing and machined the lot true. there is a M14 x 1.5mm bolt which clamps the blade to the shaft and hub plus a M10 grub screw, no more wobbles.
8. Plasma cut out a slot in some 5mm plate to fit a M14 x 1.5mm bolt which clamps the frame to the right blade depth.
9. Plasma cut out some 3mm plate to make the lower blade cover/dust collector, added some 3mm x 25mm flat bar for the sides and added a piece of 40m tube for the extractor hose
to clamp to.
Originally this was going to be a 12" saw, so I made the frame to suit but with the drama I had with the blade wobbling I ended up getting an old 14" blade to see if it was a
faulty blade(which it wasn't), so I figured I might as well make it to accept 12" and 14" blades, which also meant I had to take out some bits from the sides to make it fit. The
larger blades come close but there is still enough clearance (just).
10.Added a strut for lift assistance when raising or lowering the frame, with the 4hp motor added the frame weighs approx. 60Kg so awkward to lift even when the other end is
pivoted, the strut makes the lifting job easy.
- - - Updated - - -
11. Added a "micro adjustment" setup, 13mm threaded rod welded to a pivoting top, a turned, threaded and knurled round bit of rod for accurate height ajustment with a locking
nut to keep the setting, the knurled adjustment is grabbed by a piece of slotted flat bar which had the flats twisted in and ground out to fit the top of it.
12. Welded some 1" SHS tube on either side of the blade to the frame body to support the top plate which stops the 3mm top plate from sagging/bending near the blade.
13. Oiled both the underneath of the top plate and the top of the frame body and then applied liberal amounts of silicon adhesive between the two to make a seal so that the top
plate doesn't vibrate in operation. As the frame was an old aquarium stand which I turned sideways and added some legs, the fit between the plate and the frame wasn't perfect
and doing this way would allow me to remove the top plate if neccessary at a later stage, otherwise the silicon would have glued it down forever, there are 4 (1/4") bolts on
the sides holding the top down as well.
Made a fence out of some 50mm x 25mm x 2mm Aluminium RHS with some bolts welded to some angle underneath and going through the fence. As the bolts get tightened the angle grabs
the underneath frame and locks it in place.
I have also made a 91cm x 230cm extension table for it for when I cut long pieces of timber but I don't have pics of it just yet.
Still to do/make is to cut down the riving blade, make a sliding fence for the saw which will be able to do angles, make a router holder and fence, but I will post those pics
up at a later stage after completion.
Cheers
Ed.
1. Making the bearing holders 1 IMG_0568.jpg 2. Bearing holder with side support welded IMG_0576 - Copy.jpg 3. Bearing mount IMG_0572.jpg 4. Cutting  the twin pulley for the top shaft IMG_0583.jpg 5. Welded the pulley to shaft and rough shaping it up IMG_0565.jpg 6. Top shaft assembled IMG_0579.jpg 7. New blade hub IMG_0775.jpg 8. Depth adjustment locking plate with nut IMG_0778.jpg 9. Bottom blade cover with hose attachment IMG_0784.jpg 10. Lifting strut IMG_0798.jpg 11. Micro adjustment and locking nut IMG_0782.jpg 12. Top shaft with pulleys, blade and tube supports both side of blade IMG_0783.jpg 13. Saw table with top 3mm plate, fence and riving blade IMG_0806.jpg
Forgot to mention that I have also started making a top cover for the blade, which will be adjustable from the side both vertically and horizontally and will connect to a dust extractor I have ordered.
That oughta rip thru some lumber like butter! Good idea on installing a blade guide on the back side of the blade, that should keep kick back to a minimum. How's the rip guide setup, cam lock?
Thanks Guys, added a pic of the extension table today so that will enable me to rip longer lengths of timber. It's made from 1" Galv. SHS with 2 removable legs out of 20mm solid rod and have height adjustable feet, the top is a 17mm layer of Form ply, drilled and tapped two 12mm bolts into the tables' end and the extension table has a slotted piece of steel which fits over these bolts and the bolts then tighten the lot togather.
In the top of the pics you can see more logs waiting to be slabbed. I made the fence lock downs out of some 1/2" allthread rod which I welded the bottom of the rod to a small piece of angle and they get bolted through a hole in the the Ally RHS, not high tech but quite effective. The back lock down fits in the gap between the saw table and the extension table. As the bolt gets tightened, the angle just grips the table frame. The dust collection/blade guard will probably be finished off early next week.
Cheers
Ed.
Nice job Ed, some nice welding there as well, though by looking at the surface of your workbench, it looks like you have had a bit of practice :))
Keep up the good work.
Cheers
Ed.
So....there's an aquarium stand in there somewhere? :LOL:
Nice work! You definitely made "metal scream"!
How about a vid of it in action? Please!
Thanks guy's, I was hoping to have it finished this week but have to put it on hold for the moment. I put an advert on the web looking for some tree trunks locally, I got a reply from a guy who said I can have a small tree that he cut down and wanted removed, well I went down to his property and turns out that small tree was a lemon gum tree about 20m long and so I have to rip the tree trunk length ways just so I can manage to get the trunk halves on the trailer, I can only put on 3 halves before my trailers load limit is reached, (and even then it is probably way over). That timber is heavy, even as a half log I cannot lift an end up without a large bar. Just as well I put a winch on the front of the trailer and drag the logs up a ramp, otherwise I would not even be able to get them up on to it. He also has some Ironbark to go, a smaller piece of about 1.5mt long and also the remainder of a trunk that is about 1.4m in diameter, the trunk has the center rotted out, but should be able to get a nice slab from the sides. I wonder how many times I will have to sharpen the chainsaw to do it though? The ironbark is about 1.5 times heavier and tougher than the Lemon Gum so should be interesting.
Pics of it in operation will have to wait for a while. My dust hoses have arrived so in the next couple of weeks I will start back on it and finish off the dust/blade covers, probably just after the new year as I would like to slab this timber before then. The plan is to slab them 100mm thick and then use the table saw to rip them up into 100mm x 35mm or 100mm x 100mm (more or less), that way I can rip them further if I require smaller dimensions and will be quicker using the table saw than by using the Alaskan mill, plus it will dry faster.
Cheers
Ed.
