[4]
Magnetic Base Work Lights, Suggestions to What Works Best?
[3]
[10] Like what you see?
USMCDOC
Active Member
May 1, 2017
136
I am sure that this will be a short thread, but i am looking for suggestions as to what magnetic base work lights that seem to work the best.. like sticking them to the back side of the splash shield of the lathe or that kind of thing.
hman
H-M Platinum Supporter ($50)
Feb 17, 2013
2,010
You might want to check this thread:
http://www.hobby-machinist.com/threads/mill-work-light-brightness-question.58226/
... or else do a general search with the terms "magnet" and "light"
Several people have also posted about liking the Ikea "Jansjo" lights (about $10). The either have a weighted base or a clamp (see links below), and IIRC, at least one member has posted about taking one off its base and mounting it on a mag base.
http://www.ikea.com/us/en/catalog/products/20169658/
http://www.ikea.com/us/en/catalog/products/20315674/
USMCDOC
Active Member
May 1, 2017
136
Thank you gentlemen! I truly appreciate it so much!
We had a similar topic a while ago ,the sewing machine light with 30 LED seemed to be popular, I really like mine (use it on the mill) and will get one more soon for my bandsaw.
http://www.hobby-machinist.com/threads/magnetic-led-light.57102/
mikey
Dec 20, 2012
4,970
Take a good, hard look at this one: https://woodturnerswonders.com/collections/lamps/products/aurora-lathe-lamp
I have one on my lathe and another on the mill. The magnetic base has a 220# pull so it won't move or come loose when the machine is running. It has a 100,000 hour LED that outputs 500 lumens from a lamp mounted on an armored flex neck that actually stays where you put it. This lamp is not cheap, nor is it cheaply made. It will put a cool, bright white light where you need it and it will stay there.
I get it -"cheap" is good, but "works good" is better.
Tozguy
Feb 15, 2013
1,828
I tried the jansjo light from Ikea and find it drastically under powered. No use at all on the lathe.
USMCDOC
Active Member
May 1, 2017
136
I believe that i am doing to get one of those "sewing machine" lights for my mother.. at 81 she is still going and making quilted items for sale..
roadie33
Dec 11, 2014
850
I did have 3 of the "sewing machine" type lights, the wife "borrowed" one for her sewing machine but had a hard time finding something metal for it to grab onto.
That's one of the problems with the newer sewing machines, they are made of mostly plastic or pot metal.
Might want to make sure there is some actual metal for it to stick to.
USMCDOC
Active Member
May 1, 2017
136
Yes.. your right..
Ken from ontario
H-M Supporter - Silver Member
Dec 26, 2016
976
If the surface is all plastic, maybe it is possible to glue a steel washer of the same diameter to that surface first ,then attach the magnetic base to it. just thinking outloud.
B
Buffalo20
Guest - Please Register!
I realize that what works for Person A may or may not work for Person B or C, that said, I've never had a magnetic light that worked with a crap. Constantly moving from vibrations or the slightest bump.
The other thing I hate about magnets on the machine tools is the swarf, attracted to the base and surrounded area. I do use dial indicators with magnetic bases, but they don't remain on the machine during use.
One of the guys I work with, has magnetic strips on the lathe back splash, that holds all of his AXA block, over time all of them have become magnetized, you are constantly wiping swarf and fine dust off the blocks before you can use them. To me the only time I want to use anything magnetic, around any of my tools, is the magnetic vise on the surface grinder.
Tozguy
Feb 15, 2013
1,828
Try to tell a miner that he is a moron for using a headlamp.
D
Deleted member 473
Hey, those headlamps are pretty handy. Mine is right here next to me getting the batteries charged up so it can go back to work in the shop!
Splat
Mar 10, 2012
1,127
I think one of the best lights for the money is this LED worklight from SnapOn. If I look into it I'm blinded for a minute. It's like an airplane headlight. ha! A freind picked this Sunlite one from Amazon. Basically the same as the SnapOn but a little cheaper. Don't know how the build quality is but the SnapOn is solid. I used some old piping to get the SnapOn up and over the lathe.
USMCDOC
Active Member
May 1, 2017
136
Thanks for the links.. you have given me food for thought!
SonofHarold - Metal Carver
Apr 19, 2018
60
I saw the little sewing machine led light recomend here in a number of places, not sure who found that one but for the price it can't be beat. Right size, strong magnet, bright without over doing it. and the flex is reasonably stiff enought to stay put. I got two ( $9.50 free shipping on Amazon) and will be ordering another pair, one for an area at the back of my garage/shop and a spare. I do hope they hold up reasonably well. I did find on paint directly on the head of the mill the mag base would tend to move a little so I am trying scuffing up the paint with some fine sand paper and see if that helps. Thanks to who ever found these.
[6]
[5] [7]
