[4]
[Metrology] Magnetic Indicator Back with 2" Travel Dial Indicator
[3]
[10] Like what you see?
HolyHarp
New Member
Feb 20, 2014
20
I have a magnetic back for my 2" travel dial indicator that I'd like to use to measure longitudinal travel. This image shows it with a 1" travel indicator .202-6056b.jpg
My first idea is to mount it on the lathe ways and indicate on the saddle. I have a few difficulties:
When I remove the indicator/base from the ways (or anything), the brass female threaded fitting comes out of the plastic indicator back.
  • Does anyone have plans or ideas for a quick-release for the magnet to easily remove it? Here's one for a Mighty Mag: 41LvB42PvJL._SX342_.jpg and for an Erick Magna Holder: 350-a.gif
  • and for a Lufkin Miti-Mite: images?q=tbn:ANd9GcQDbBMn6Vy2K6PaCndhvtW3bSyAndp7pxSX0lCJtv92nJd5hBivKA.jpg
  • Is there a way to easily slide it along the ways to get it in position?
Mounting it on the ways is really only good when using the auto-feed or hand wheel to move the saddle. What can I indicate on when I have my saddle locked and am using my compound rest at 30° to advance my cutting tool (turning or boring)?
  • Mount it on the T/S ram and indicate on the tool post? This would require the tool post side to be flat. How could I easily make sure it was square to the lathe axis? Here is a similar setup:
  • Putting a Mighty Mag on the face of the T/S ram might work. hqdefault.jpg
What ways are there to use it to measure depth of drilled holes? Would a different magnetic base be better? I have several magnetic bases and a lugged indicator back I can change out to. I have an indicator stem holder as well.
  • Find a way to mount it on the tail stock and indicate on a Neodymium magnet back (from a PC hard drive) on the T/S ram?
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,190
Read the link more carefully, Daryl. Parts only...
HolyHarp
New Member
Feb 20, 2014
20
To square the side of the tool post to the lathe axis requires turning the cross-slide back and forth 2 or 3 times. Can anyone think of a quicker way?
kd4gij
Feb 7, 2011
4,698
I have the same magnetic back in your picture. Had the same problem you did. Made the part out of aluminum and it works great now.
HolyHarp
New Member
Feb 20, 2014
20
@kd4gij, it would be great if you could share a dimensioned sketch or drawing of what you made and any tips or techniques to make it.
kd4gij
Feb 7, 2011
4,698
I took the stock back plate from the indicator cut the lug off. Clamped it to a piece of square aluminum milled the lug flush. drilled and reamed for a press fit for the brass stud that pulled out of the plastic back and used red loc-tite to hold it.
[6]
[5] [7]
