- Jan 25, 2015
- 2,558
My Atlas TH42 has it's original 4 jaw chuck. It has "Atlas" stamped right in the face.
It's a good old soldier and it works, but it's sloppy and takes a fair amount of fiddling to get it dialed in. On the plus side, I've gotten pretty proficient/quick at mounting stock in a 4 jaw chuck!
The key slots in the body seem worn/sloppy, which makes tightening and adjusting an extra hassle. The jaws will often not have a square grip on the work piece either. To the point where you can look in to the jaws and actually see they don't have full contact along their length on the work piece.
I suppose I could try "refreshing" the old chuck, but I'm pretty sure it's close to the end of it's useful life with the way the jaws move inside the chuck body slots. Again, they're not completely horrible, but you can feel the slop when you grab them and I can't see how I would be able to compensate for material that has been worn away over the last 60-70 years of use.
I've got a "new" 4 jaw chuck I picked up a long time ago, before I even bought the Atlas. If I recall, it's an "ebay special". IE: No name. It's roughly the same size as the orginal Atals chuck with a body that measures 6.25 across it's face (The Atlas is 6.00). But it has one advantage over the atlas chuck: it's not worn.
So I'm looking to cut a back plate for it and try it out. This is something I've never attempted before, but you gotta start somewhere!
Getting a pre-machined plate would be prohibitively expensive where I live. Even just the shipping would be crazy. I'd love to be able to, but it's just not in my budget. I'm also looking to start learning thread cutting.
Getting a chunk of cast is also not an easy option here, it's just not something that's readily available. A chunk of steel the right diameter is possible, but not cheap either. Tariffs and whatnot have driven the price of metal crazy here lately......that's all I'll say about that.
By the same token, having a local shop make me one (even if just a raw plate with threaded center hole) would also be crazy expensive.
So I'm left with making my own plate and with something I can source locally.
First hurdle is the internal threads. Boring to size I can do, but I've never cut threads. Let alone internal ones. It seems reasonably easy from the videos and manuals I've seen, set the gear train to the right combo and run 'er in and out. But I'm not as naive to believe it is going to be that easy. I'm thinking I need to practice a bit before trying to cut the plate. I do use collets in the Atlas, but I don't have a nose guard for the threads. Perhaps I should practice by making a thread guard before moving to cutting the plate? That wouldn't be too expensive, it's something I need anyways and would be the exact threads I need to cut in the plate. Seems to make sense to start there.....
The cast iron plate is another issue. As mentioned, it's not easy to find here and crazy expensive to ship something in. I do have a couple of older cast iron weight sets and a couple plates measure out to about the right size. I know weight set cast iron plates can be a crap shoot as to what is in them, but I don't have a lot of options here.
Carbide tooling is what I will be using and I have lots of inserts available. If it cuts reasonably well without killing a carbide insert, I should be able to carry on making the back plate and have a decent finished product, right?
Which brings me to the method of cutting the plate on the Atlas. I'm not sure the current chuck will be big enough to hold the cast iron weight. There's enough swing over the bed, I'm just not sure I can get an adequate grip on the raw plate. Both because of the rounded outside edge of the plate and the amount the jaws would likely have to be out of the chuck body. At least not well enough to bore it and cut the internal threads. So what are my options to mount the plate (or a chunk of steel) for at least getting the center hole bored and threaded? Once it's to that point, the rest gets easier because it's at least on the spindle and I can make the diameter/chuck registers.Once it's mounted on the spindle, I'm back in my wheel house for machining procedures.
So, any advice here?
