- Dec 26, 2017
- 60
I made a post about this on another forum, it got hung up in moderation for three days, they released it, and then the site went down. Lets see how my luck holds up...
I volunteered to restore a coworkers 1941 Silvertone farm radio. It was his grandparents radio. They used it on their ranch in NE New Mexico. To this day it's a fairly remote area. It runs on a 90VDC and 2.5 VDC batteries. The 90V battery can be made from ten 9V batteries in series. That will last about 6 months. I've finished the electronic restoration and I'm not working on the only mechanical problem I've found. The dial pulleys are made of wood and one of them has failed. My initial plan was to make a new pulley from brass. Here's some photos to show what I need. I'm going to make both pulleys even though one is still good. More on that in a bit. No more skill than I have with my mini lathe I'll probably make a few that don't look like a pulley too. The "CAD" drawing was made with Mike CAD. The software is not for sale
The most pressing problem that I have is how to get the pulley off of the old (aluminum) shaft. I could chuck the hex end up and turn the ball down and then capture the new pulleys with a pin (1/16" hole to drill. That won't be fun). I could remake the shaft assembly out of brass, turn the axle to a larger diameter so it will be easier to drill, and then make the hole in the pulley larger. But I can't change the v groove OD, a little less than 1/4" so I can't increase the hole by much. Also, I don't know if brass on brass is a good idea. What's a good way to cut the v-groove. I thought about making a form tool but I really don't know how to do that. Thoughts? My guess is that this isn't a beginner project. That's one reason I bought 12" of stock
