[4]
Materials and metric gear conversions
[3]
[10] Like what you see?
Brento
Active Member
May 9, 2018
133
Hi all so im in need of some blocks of aluminum steel anything you may have alot of. Start to get materials to do projects and figured it may be worth asking on here before i try buying from amazon or msc.
The other thing is im looking for 2 change gears for my SB 9A. I need the 2 gears to do some metric threading. Now i believe i found them on thingiverse that id be willing to try however i dont have a 3d printer.
Brento
Active Member
May 9, 2018
133
If i remember correctly i needed a 54 and 80 tooth gear for metric threads.
pstemari
H-M Supporter - Gold Member
May 18, 2015
415
A 127 tooth gear is needed for an exact metric conversion, but there are simpler/cheaper combinations, eg 37:47, that will get you to within the accuracy of your lead screw.
See http://www.loganact.com/tips/met-thd.htm or Screwcutting in the Lathe (Workshop Practice Series) http://amzn.com/0852428383 for more info.
Sent from my Pixel XL using Tapatalk
RandyM
H-M Supporter - Commercial Member
Staff member
Apr 12, 2011
2,356
Help me out here, but what is aluminum steel?
[6]
[5] [7]
