Mattsson & Zetterlund VF600 Restoration
Red Baron FC
Nov 8, 2018
35
Hello. Recently I bought myself a birthday present. No need to mention that my wife was not so excited as me :) This is my first serious machine. It is Mattson & Zetterlund VF600 (small) vertical milling machine. More about this machine can be found at: http://www.lathes.co.uk/mattsson&zetterlund/ . I hope I will restore it properly so it
will shine and be used again as intended. For sure, I will need advice and help down the path, so, I will post a pictures, comments and questions here. Wish me a luck :)
There is some pictures of machine as it was when arrived.
Red Baron FC
Nov 8, 2018
35
It took me about three hours to disassemble main parts. I was able to do it by myself. At the second picture a big round hole can be seen. Through this hole screws for tightening axis nuts can be reached. To disassemble table, screw that tightens X axis nut must be loosen, completely. I was not know that at the time of disassemble, so, I was take down table with saddle. Much harder way. Although there was chip guard to protect Y axis screw the column of the machine was full of chips. It can be seen at third picture what was in the machine column. Main parts can be seen at fourth picture, table in front, small wise that was came with machine, Z axis angle adjusting housing with worm gear, spindle, X axis power feed, and Y axis saddle. Next two days was gone in removing grease and dirt from column and base of the machine.
Red Baron FC
Nov 8, 2018
35
I was need a help of a friend to move column in to the shop. Column are lighter than base. We are barely succeed to move the base. More cleaning and removing dirt and grease from base. Almost five hours, using this special chemical for this purpose, shown on first picture. Way oil is a pretty sticky thing. AKRA K2 is a nasty thing. It dissolve grease, but it soften and dissolve paint too. Whole lot of a mess just to get base of the machine at stage shown at next few pictures.
Red Baron FC
Nov 8, 2018
35
Today was sunny day, so I fulfill it with more cleaning the remaining parts from machine. Not so interesting at all. But just to say this activity swallow more four hours. Again, way oil, especially old way oil is a pretty sticky. Then rest of the day I start a rebuilding process. There is a picture of two part chip guard metal plate after cleaning. There is some rust but nothing dramatic. By the help of 200 grit water sandpaper it became almost clear enough. Third and four picture show state after sanding. I was not satisfied so, I try jeweling it. Officially my first attempt to do jeweling can be seen on fifth picture. I use 50mm blue scotch brite pad with WD-40 and move it by 25mm in both directions. Second attempt with 12.5mm moving pattern and final result. First finished part. :)
Bob Korves
H-M Platinum Supporter
Jul 2, 2014
7,273
It looks like a nice machine for a home shop. Reading the post on lathes.co.uk and seeing it has a 30 taper spindle and is solidly built makes it all the more interesting.
bl00
xxxxxxxxxxxxxxxxxxx
Nov 26, 2011
111
I like the jeweling. That looks nice! There's a good post on the Svenska Elektonikforumet showing a conversion to cnc. It has plenty of pics of the machine apart which is useful even without the cnc part. You may need to join to see pics: http://elektronikforumet.com/forum/viewtopic.php?f=3&t=71104
I converted the manual to English, but lost it to a hard drive crash. I started over, but haven't added in the images, yet. Send me a message with your email address if you want a copy.
Here's what mine looks like-
Red Baron FC
Nov 8, 2018
35
Red Baron FC
Nov 8, 2018
35
Thank you for your replay. I plan to convert it to CNC, some day. :) but for now, I do now want to bite something that I can not chew :)
hman
Feb 17, 2013
2,660
O, off topic ... but how crazy is it that here on the forum we have a Serbian and an American discussing a (relatively obscure, from what I understand from lathes.co.uk) Swedish machine tool that they both own?
I'm just waiting for an Australian or east Asian member to chime in and say he has one, too! :)
FOMOGO
Sep 2, 2013
2,206
Nice little mill, and great job getting it cleaned up. What you call jeweling, I've always known as engine turning. A rose by any other name. Cheers, Mike
Red Baron FC
Nov 8, 2018
35
English is not my mother tongue, so, excuse me if I use wrong words. I remember when I was try to found correct word to type it in google, to find how to do that. Good for language practising :) I found this type of work call swirl too. Whatsoever, I think it is nice way to mask dents and scratches. Another reason to do this is merely an exercise in this type of work.
Red Baron FC
Nov 8, 2018
35
Today was perfect day for little activity in workshop. I was scraped all paint and some putty from base using old chisel. I took me about six hours to complete the job. Great activity for stress relief :grin: plus exercise in sharpening chisel. Who could ask more from saturday. :rolleyes: The reason behind this work is many places where putty was pop up from cast iron, manifesting as little cracks in paint, looking just like when a small rock hit a glass on car. It can be seen on fifth picture. Those places where putty was pop up are white on pictures, there was left only a base paint on metal. Dark grey is where old putty is good enough to stay in place. Grey pile of something is what was scraped off. Weight about 1,5kg.
Now, in the next few days I will prepare the base for paint. I have no compressor nor ability to move the base somewhere to paint it, so I plan to paint it with brush. I see people paint restored machines with all sort of paint. My plan is to use enamel paint, but I will like to hear some advice on this. Is it a god choice or not. Do you suggest something else? The color will be pure white or RAL 7035 although RAL 7035 looking to me to dark either.
middle.road
Actively Learning...
Apr 28, 2014
2,940
You're doing fine so far, no problem.
It is cool to see what other folks in other parts of the world have in their shops.
Red Baron FC
Nov 8, 2018
35
Hello again. After some flu sickness and holidays I was a little busy. I done some body work with a polyester filler, shown on a first picture. After sanding I was spray a two layers of primer. That was yesterday. Almost whole base is good, but there are spots where thing are not good. I show those spots on next two pictures. When I was scratched those spots with finger nail or sharp object I was get result as on fourth picture. Been intrigued with those errors, I was decided to be a little more aggressive, so I get a result shown on last picture.
Now, silver zone surrounded by green line are bare metal from casting. On top of that there is a light yellow and light grey zone surrounded by red line that was left after pretty aggressive scratch attempt, having, obviously a god bonding. Light yellow thing is polyester filler and light grey thing is primer. Dark yellow thing surrounded with brown line at the top of the picture is old putty-filler that goes on bare metal casting, on top of that goes dark grey thing surrounded by blue line which is also some kind of putty.
So, I guess I have a problem with new polyester filler to old dark grey filler bonding, but, those errors are not massive. So, at this particular moment I contemplate about what to do. Sandblast whole thing would be a good solution, but I do not have ability to do that. To make just a correction where errors is shown is another solution, but there is no guarantee that there is a good bonding where errors are not shown. Bonding is maybe just good enough to not show errors, but not good enough as it should be. Last but not least, I can redo the whole base, but, the previous question will remain, how to be sure that I have a god bonding between old putty-filler and new polyester filler?
Any suggestion?
markba633csi
Apr 30, 2015
4,577
Hi Red Baron- I think the filler will adhere well, I would not worry- just do spot fills, sand and paint
Nice machine
mark
Red Baron FC
Nov 8, 2018
35
I was a little busy :) Pictures show saddle before and after cleaning. Only the lubricating nipple was changed. These have M6 straight thread versus DIN71412 that has M6 tapered thread. All ways are more or less wear, so, at this stage, it became mainly cleaning-painting-lubricating, bearing and small parts replacement project. The reason for this is that currently, I do not have the necessary skills to scrape the ways. IMG_0171.JPG IMG_0172.JPG IMG_0173.JPG IMG_0174.JPG
Red Baron FC
Nov 8, 2018
35
For lubricating, I use one of this, with epoxy glue in the hole at the bottom. It costs me less than 10 euro. The idea for this a get from Stuart de Haro.
Video can be watched from
Red Baron FC
Nov 8, 2018
35
Now, about lubricating, Service Manual calls for Gulf Harmony 53, basically for everything except gear and spindle. There should be used EP2 grease. I am attaching relevant pages from Manual, so, if someone here knows Swedish I will appreciate help in translation these pages. What was intrigued me is that Gulf Harmony 53 is essentially a Hydraulic oil, even for ways it recommends the same hydraulic oil and not a way oil, which is perfect to me, but some kind unusual.
Red Baron FC
Nov 8, 2018
35
Finally, the machine at their place leveled with base, chip tray, and column. I am very happy. IMG_0210.JPG IMG_0214.JPG
Red Baron FC
Nov 8, 2018
35
Gibs for saddle can be seen at these pictures, so it will partially explain why I said that this machine will need way scraping one day. IMG_0204.JPG IMG_0205.JPG IMG_0206.JPG IMG_0207.JPG
Red Baron FC
Nov 8, 2018
35
Well, servicing a Head and spindle was quite challenging. First, do be able to disassemble spindle, quill must be removed from housing. It goes up, but only after quill handle with returning spring was removed. Here is some pictures from the state "before" :).
Red Baron FC
Nov 8, 2018
35
Head is moving up/down with with the help of Rack & Pinion mechanism. Tilting a Head is accomplished with Worm Gear mechanism. This machine was used (and abused) as it can be seen on worm gear (on first picture). Luckily, I was able to rotate Worm gear for 180 degree, so part of worm gear where teeth was broken are not engaged any more. On third and fourth picture mechanism for moving head up/down and tilting Head can be seen, mounted on the machine.
MontanaLon
Mar 15, 2019
662
That is a very interesting machine. Seems to be comparable in size to a round column mill drill but with better rigidity. Too bad they are rare, I will probably never see one in person.
Red Baron FC
Nov 8, 2018
35
Now, starts the fun :dejected: Outer race has to be removed from Housing. But, there is no place between race and Housing for claw to catch race and pull it. There is interesting video how this kind of problem can be solved. It was help me very much.
...and this is how I was do that :) On first picture, inner thread of the Housing is protected or "protected" with thin metal plate stuck on the position with masking tape. Piece of bar stick welded to inner race on the second picture. Finaly, inner race removed from Housing on third picture.
Stick welding is not the best welding method for this operation, but, it is the only welding method available to me at this moment, so I did it with what I have. Completely successful. :cool:
AdBlock Detected
I've Disabled AdBlock
