I am cross posting this question to several forums.
I have 2 Proform MC-60 treadmill motor controllers, one of which is currently running my X2 mill with its (from the treadmill) 2hp motor.
I have it set up with the original heavy choke, and the original line switch/circuit breaker from the treadmill, and a 5k pot from radio shack for speed control. It works, but still has the soft start feature, and the pot must be turned up about 50% to start the motor. I found some instructions for modifying this controller to remove the soft start, and one that supposedly will allow setting speed and being able to turn the motor on and off at the last speed setting. Only problem, the controller schematic provided with these instructions, doesn’t seem to match the Proform MC-60 I have.
Has anyone modified this controller to remove the soft start? Will a 10k pot make the speed transition smoother?
I have a data sheet on the controller from Surplus Center which pictures the board and shows the connections, but not a proper schematic.
Chuck in E. TN
Chuck in E. TN
