[4]
Metal Scale....1/10 measure question
[3]
[10] Like what you see?
outsider347
Sep 3, 2012
307
Likes
32
#1
Pretty basic question here.
Why do machinist metal scales measure in 1/10?
BROCKWOOD
H-M Supporter - Gold Member
May 26, 2017
480
Likes
289
#2
Simple answer: Machinists measure & think in terms of thousandths. A scale marked in 10ths is readable & readily transfers a rough measure for the selection of stock. Most of my little 6" rule collection is in 16ths, so I have to convert. I don't mind as it helps me think & focus on the real numbers & memorizing the values of various fractions.
F
f350ca
Guest - Please Register!
#3
A couple of years ago I found a 12 inch scale in 10 ths. Thought wow will this be handy. Turns out I never use it, Im so accustomed to thinking fractions when I pick up a rule the 10ths seam foreign.
Greg
benmychree
John York
Jun 7, 2013
2,756
Likes
1,994
#4
This scale was used by the aircraft industry; I have one with hundredths! At the age of 73, its pretty much of a blur, even with cheaters ---
outsider347
Sep 3, 2012
307
Likes
32
#5
Greg
Yea same with me. I asked because I thought that I was missing a technique
brino
Jan 2, 2014
3,461
Likes
3,487
#6
When I am working with wood (esp. dimensional lumber) I find fractions work best(16ths and 32nds).
When I work with metal, I'd rather use decimal inches.
Mostly because I cannot cut to the thou with my skill saw, and even if I could then humidity changes would negate that.
I thinks it's mostly about how accurate your work can be given the material.
Maybe also because my calipers and micometers are slanted towards decimals.
Sometimes I work in metric, if the need arises, but then I am usually converting the imperial measurements on the lathe and mill handwheel dials.
-brino
rock_breaker
H-M Platinum Supporter ($50)
Dec 31, 2010
552
Likes
265
#7
Engineering drafting scales are setup in 10ths or divisions of 10ths. Back in the day prior to satelites and after the 66 link chains surveying was done in10ths and hundredths. I like using 5 squares to the inch graph paper because it makes working with shop drawings easier. Worked in a housing subdivision project for a while, engineers set grades for sidewalks and push outs using inches and fractions because that is what the carpenters used. Later on got to using cubic yards and tons, makes for all kinds of useful conversions floating around in the head.
Have a good day
Ray
[6]
[5] [7]
