Hi all....a small part I am making is tapped on each end and I need to pick up the taps to complete the job. I have checked the threaded ends of the mating parts and am a little confused. One of the threaded ends measures 7.75mm in diameter and a 1.0mm thread gauge fits perfectly, so I'm assuming that would be a 8.00mm x 1.00mm tap for that end. When I measure the other part end it measures 3.00mm across the threads, but the diameter just past the thread measures 4.00mm. The pitch seems to be .6mm. So I'm not sure which tap I need for this. I'm thinking I need a 3.5 x .6mm, but I'd like to get your opinions before I order them.
Thanks
Thanks
