So I recently purchased this mill , everything works great except for the low gear setting , I noticed the cam pins are loose out and the actually internal assembly was not sliding up and down without force. I took the top cover off and got everything to slide up and down. There is also no set screws that hold the cam pins in. Could this be a factor ?
IMG_4583.MOV10 MB
