- Dec 31, 2010
- 937
I have an Enco Power Feed on my Enco 105 mill/drill that when used for steel is run at very slow speed; probably 10% or less of the speed control lever throw. My question is would it be better to install a smaller pinion (fewer gear teeth) so the motor runs at a somewhat higher speed? Obviously more teeth on the X axis lead screw would accomplish the same result. There have been no problems with the power feed to date when used. All constructive replies will be appreciated.
Have a good day
Rock Breaker
Have a good day
Rock Breaker
