[4]
Mill vise mounted to swivel Base?
[3]
[10] Like what you see?
Firstgear
H-M Supporter - Gold Member
Dec 7, 2018
489
When a mill vise is mounted to a swivel base, what keeps the mill vise from rotating or moving around the center pivot?
7milesup
Jan 7, 2016
387
There is a concentric slot that lie underneath where the hold down tabs for the vise are. The bolts that would normally hold the vise down go in the slots to allow rotational movement but can be tightened to prevent rotation. The base has two holes (or slots) where the hold down bolts go which attach to the T-Slots in the mill table. There is a registration pin in the center of the rotating base for the vise to rotate about.
Firstgear
Dec 7, 2018
489
Ok, that makes sense. Where can I get the bolts that hold the swivel base to the mill bed? I tried some of my clamping kit T/bolt/nut but that assembly was too high for the swivel of the mill vise. The mill vise would move about 15-20 degrees before it hit the nut.
Thank you in advance!
shooter123456
Active Member
Jan 20, 2016
449
Do you still have the packaging for the vise? Mine came with 2 sets of them.
Firstgear
Dec 7, 2018
489
I didn’t see anything. It’s a brand new Kurt D60....I just double checked the box and there is just cardboard.
7milesup
Jan 7, 2016
387
I have some low profile nuts, which you might be able to find at your local hardware store. I am not familiar with Kurt regarding their bolts so could not tell you if they are metric or SAE. Sorry I could not be of more help.
If it was me I would take my nuts (well, the vises anyhow) and grind them down for clearance. Make sure you hold onto your nuts securely lest you lose them, then the wife will ask you what you are looking for and when you answer that you are looking for your nuts that conversation usually gets you nowhere...
benmychree
John York
Jun 7, 2013
3,548
Make T bolts from square stock turned to size; do not use hardware store nuts, they are small diameter and could chew up the slots in the base, if you are able, make the nuts with flanges that are large enough diameter to have good bearing on the vise base.
mikey
H-M Platinum Supporter ($50)
Dec 20, 2012
5,540
Unless you really need the swiveling feature, why not just take it off and use the vise without it? Most of us do that and the swiveling base sits on a shelf for decades or more.
middle.road
Actively Learning...
Apr 28, 2014
1,735
A brand new Kurt? Did you by it from a vendor? I'd contact them or even Kurt then.
And then there is what Mikey stated, a bunch of folks don't even use them, me included.
Firstgear
Dec 7, 2018
489
I’ve got it.....maybe over time if I don’t find a real use for it, I will take it off. There seems to be a mixed vote of those that use and those that don’t.
mmcmdl
Staff member
Jan 31, 2016
1,848
Shorten your bolts ! ;)
pstemari
May 18, 2015
455
Or buy some cap screws that fit your t-nuts and are short enough to not bottom out in the nut.
Sent from my Pixel XL using Tapatalk
Firstgear
Dec 7, 2018
489
I will look at my height that is available and get the appropriate pieces today.....stay tuned....
Firstgear
Dec 7, 2018
489
Decided I could cut down a couple of my threaded rods that came with my clamping kit I got from PM. I also had to cut down the nuts top just a hair. Since my mill and the lathe don’t have power yet, I used my bench drill press and my die grinder. It isn’t as pretty as it could be but looks good enough. A little paint and the pieces look good as new.
I saw where another forum member bought some neoprene on eBay, https://www.ebay.com/itm/NEOPRENE-RUBBER-1-8-THK-X-12-x-48-WIDE-SHEET60-DURO-5-FREE-SHIPPING/264099841122?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649 , it was $15.75. I thought that was cheap insurance for the bed. I have a couple of aluminum plates that I can put on top of the neoprene that makes that area a bit bigger.
kb58
H-M Supporter - Silver Member
Jan 10, 2019
244
... Make sure you hold onto your nuts securely lest you lose them, then the wife will ask you what you are looking for and when you answer that you are looking for your nuts that conversation usually gets you nowhere...
She'll probably say, "I know that's not true because I've got them right here in my pocket..."
[5] [7]
