Mill vise stop using split cotter clamps
Technical Ted
Nov 5, 2016
1,418
Just finished up my latest project, a mill vise stop using split cotter clamps. Giving credit where credit is due, I basically copied the one here, with just a few minor tweaks for my usage:
http://www.cnccookbook.com/MTMillKurtViseStop.htm
It's surprising how well these split cotters hold with little pressure. Nice and secure. I attached a drawing just in case someone wants to make one or is just interested. Just tweak things where needed for your individual set up and use.
20170910_121402.jpg 20170910_121435.jpg 20170910_121604.jpg Mill Vise Stop v9.png
I drew it up in Fusion 360 (which I love!). The screws were imported from McMaster-Carr, but I did not use those. As you can see from the pictures, I made up my own. They are 1" in diameter on the knurl x 1/4" long and 1/2" on the shoulder x 1/4" long. The shoulder got the finger wheel a little farther away from the block and this made it much nicer to use.
Have fun!
Ted
  • Mill Vise Stop Drawing.pdf
Nice job of work. I still prefer the stop mounted on the jaw, no joints to worry about . Yeah, there are times it won't work. Then I use your type of stop.
Nice job. Well done.
I was not familiar with the term split cotter, but now I know. Mr Pete222 recently took apart a NOGA clone DRO arm. It uses similar joints. As you mentioned, a lot of holding power for little force.
Same clamp design that is used on a lot of lathe tail stocks to lock the spindle, drill press quill locks and a lot of other places where a lot of clamping force is needed that doesn't mar things up when doing so.
Ted
Thanks nice job , on my to do list also. And a free standing model with mag base.
