Mill Vise
Cross Slide
Aug 17, 2016
5
I'm brand new to machining. So new that my machines haven't even shown up yet.
I'm getting a Craftex CX600 Mill / Drill.
The working surface of the table is 20"x7" with three 3/8" T-Slots.
I'm wondering if there is a certain size of Mill Vise that I should be looking into?
I don't want to buy the wrong Vise that I will find to small or to big once I try using it.
Personally, I would go with a 4". I have a RF-30 mill drill and a 5" vice. I have to use the T-slot closest to me for clamping so that the vice doesn't overhang the front (side closest to the column) of the table. I do have a 4" and like it better because it give me more options for positioning and clamping it to the table without restricting travel.
Tom S.
Thanks for the info Tom.
The company I'm getting the machine from has what looks like a nice 4" Vise. I will go with that one.
Trevor
I agree. I got a 4" vise for my Chinese mill/drill and I don't think that I'd want to go any larger on it.
I got a good deal on one from Discount Machine on ebay, which is Shars. I got the swivel base because it was only $5.00 more than the same vise without one. It has worked very well for me.
http://www.ebay.com/itm/SHARS-4-x-4...ase-CNC-New-/330717190280?hash=item4d0047d888
But I checked the shipping to Canada. Unfortunately it's $126.00. I paid $38.00 for shipping. Still, if you're paying more than $200.00 USD it might be worth it. Or if Shars has a distributor in Canada you might check it out.
http://www.shars.com/4-x-3-93-lock-down-precision-milling-machine-vise-with-swivel-base
Thanks for the link Charles.
That is a very nice Vise. I may have to go that way.
I bought my 4" on eBay for $98 delivered. Not super precision but didn't expect it to be for the price. Ebay has a big selection and price range. I'm sure you can find something that fits your budget and accuracy requirements.
Tom S.
I got this one from a Canadian seller on eBay. It's a great fit for the mini mill. The angle in this pic makes it look a little longer than it really is. Jaws are 3.5" wide and open about 4.85", which is the widest opening I've seen in a vice this size.
The seller is quality_machine_shop, located in the Toronto area. They don't appear to have any listed at the moment but you could always contact them.
http://www.ebay.com/usr/quality_machine_shop
I have an RF-31 mill/drill and a 4" Kurt vise fits it perfectly and allows full Y-travel. A larger vise would restrict Y-axis travel or put the rear jaw in a less than ideal position. My table is 8 X 28, so for your 20 X 7 table I should think a 3" vise would be better.
The vise size is not just about capacity. It must be bolted down to the table and this puts the rear fixed jaw in a certain position. That position greatly influences how much Y-axis travel you have. The bulk of the vise that projects behind the rear jaw can also contact the mill if the vise is large, further restricting Y-axis travel. Accordingly, you want a vise that is sized to the mill and table size.
Since 90% of your work will probably be done with the vise, having an accurate vise is really important. If I were you, I would buy a 2-3" screwless import vise that is accurate into the low tenths. This will give you accuracy, enough capacity that should match what your mill can handle and allow you time to learn to use the machine. During this time I would look for a used Kurt D30 3" Anglelok vise on ebay. They come up from time to time and generally sell in the mid to high $300.00 range - if you find a good one, buy it if you plan to stay with your mill. If you sell your mill you can sell the Kurt D30 for what you paid and move on ... and it will sell, I assure you.
A milling vise has to be pretty accurate and it must hold the work solidly without causing it to rise when you clamp the work down. A screwless vise will do all of this, as will a good Kurt vise. Size it to your mill so you can use all the travel the mill has and you'll be fine.
Thank you for all the info guys.
It gives me something to think about.
My plans may have changed now. I was about to place my order for the brand new equipment. Then I was offered a used lathe and mill (maybe 3 years old). They are both bigger then I was planning to purchase. But bigger is always better!!
I'm just waiting to go see them in person. The price he wants for both pieces is around what I was going to spend for just the lathe new. So I don't think I can really pass them up. Plus I get all tools, accessories, etc. that he has for both pieces!! That will include a new 5 or 6" Mill Vise!!!
Trevor
