- Mar 26, 2018
- 8,406
Hi,
The last time I welded was in 1983. The time before that was 1974-1975, the year I graduated from Ygnacio Valley High School. Welding back then was either , Arc or Oxy. Acetylene.
Will the Miller be an all purpose hobbyists welder?
Aluminum, mild steel, I want a welding machine that will perform flawlessly and uses the latest technology to dial in, material being welded, thickness, readily available consumables, easy to read panel, quality construction..... etc.
I don’t mind spending the money, I just want the right fit.
Thank you.
Thank you.
