I'm in the middle of watching Blondihacks,and Quinn mentions "3 in 1 machines". As it happens, I am in the middle of buying material to build a milling attachment for this machine. The drawback I see to these milling attachment is a very limited (6 1/2 in. total) in /out (cross slide) axis travel.
Yes, I know that Mr. Pete just did a 2 part series on building a offset base adapter plate for the south Bend lathe. I could do that for my Craftsman 101 but I don't think the offset would be very well supported. There is a lot of flex in that carriage assembly to begin with.
I know I don't want to try to do a drill press conversion. I know that a add on head would be a light duty kind of deal ... but in line with the capabilities of the lathe. I know that I would not be able to raise or lower the mill table.
NO! I cannot afford a proper milling machine. And NO I don't want to buy something cheap from over seas.
I'm kind of wondering if there might be an affordable Mill head from one of those 3 in 1 machines that might bolt on my Craftsman lathe ... and why this might be a bad idea. Mounting the head to the lathe base would just take doing it. Small slotted mill tables are available and fairly inexpensive. The Atlas/Craftsman already has a power feed.
Ever seen anything like this done on this type of machine?
Got suggestions where I might find a milling head assembly that might work?
Is this the craziest thing you ever heard of?
Thanks.
Thanks.
