[4]
Milling with 2 cutters
[3]
[10] Like what you see?
rock_breaker
H-M Platinum Supporter ($50)
Dec 31, 2010
552
Likes
264
#1
Learning about pictures, Making Tee nuts on my Atlas horizontal mill. Lots to learn but a lot of fun.
T Bredehoft
Dec 27, 2014
2,787
Likes
2,133
#2
That's exactly what a horizontal is good for. If only....Nope, won't happen.
P. Waller
Mar 10, 2018
796
Likes
527
#3
Pinch milling, it is especially useful when milling thin parts subject to part deflection applying equal load to each side.
benmychree
John York
Jun 7, 2013
2,737
Likes
1,982
#4
This is commonly called straddle milling, works best with a pair of milling cutters with side rake, one cutter is left handed, the other is right handed, they cut more freely than side mills with the teeth having no rake; the way the cutters shown (stagger tooth) cut in the same manner as the pair that I mention, but only half of the teeth are doing much cutting; stagger tooth cutters are best adapted for cutting slots, having side rake on both sides, the finish better and the alternate spiral of each successive tooth tends to suppress chatter, which side mills tend to do.
Horizontal milling is my favorite kind!
rock_breaker
Dec 31, 2010
552
Likes
264
#5
I must inventory the tooling that came with the mill again, if I have side rake cutters they are for larger spindle. Making larger spindles are on the "to do list" and having the mill/drill does lend itself to completing projects a little faster. As shown in the picture light cuts .020 keep the motor drawing approximately 4.2 amps (it is rated at 4.0 amps).
have a good day
Ray
[6]
[5] [7]
