- Nov 26, 2017
- 1,515
I am looking at this mill on an auction. It is across the country so I cannot visit in person. I am looking for any input someone might have (Value, concerns, issues, etc).
Also not that it calls out below a Spindle Taper of 30. Is this the NMTB taper format?
The spindle in the video sounds like it might need some new bearings. Hard to tell from the video. But it is louder than I would expect compared to another one they are selling.
Milltronics Partner 3 CNC 3-Axis Vertical Knee Mill with Centurion 6 CNC Control
Equipped With:
Centurion 6 CNC Control, Power Quill Feed, Programmable Vertical Head Feed (Z), Knee Handle, Mitutoyo Quill Scale, Power Drawbar, 30 Taper Spindle, Vaaribale Spindle Speeds 50-4,200 RPM in 2 Ranges, Chip Pan
Description:
Control UPdated to Milltronics Centurion 6 CNC
Electrics:
220 Volt, 3 Phase
Manufacturer: Milltronics Model: Partner 3 Year: 1994 Serial Number: 2597
Main Unit Approx Weight: 3500.00 lbs
Main Unit Dimensions (in inches): Length: 80.00" Width: 68.00" Height: 89.00"
Specs:
Control: Centurion 6 CNC
Table Size: 10" x 50"
Machine Travels (X/Y): 30" x 15"
Programmable Z-Axis Travel: 6" Programmable Z-Axis Head Travel
Quill Travel: 5" Hand or Power Quill Feed
Spindle Taper: 30 Taper
Spindle Speeds: Variable Speed (2) Ranges 60 -500 and 500-4,200 RPM
Spindle Drive: 3 HP
Equipped With:
Description:
Electrics:
220 Volt, 3 Phase
Specs:
Spindle Drive: 3 HP
