That's the coolest thing I've seen in ages- even sounds (and leaks) like a Harley! Is there a muffler on it? It's so quiet! Did you design it yourself? Very impressive
Mark
ps did you say you wound the ignition coils yourself?
No I don't have a distributor it functions on 2 hall effect sensors. I designed this myself so I'm just happy it runsAt a guess, you don't have a vacuum advance on the distributor. That would help with acceleration. But I suspect you know that.
Unfortunately my camera was acting up back then so I only have a couple videos on that. It uses a tandam board that I came up with and 2 coil packs. On the motor I do believe in the build I go over how I put 2 hall sensors back to back and put magnets in the cam gear one with + facing sensor and one with- facing sensor. I could post a PDF file of the circuit board if that helps.Doc: just found your videos on you tube- did you do one covering the ignition system and the circuit board- I would be interested in seeing that
Mark
