[4]
Mini-lathe Zero-resettable hand wheels?
[3]
[10] Like what you see?
rfresh747
New Member
Dec 16, 2017
25
I'm interested in the Harbor Freight 7x12 mini-lathe. I was wondering if there was a modification to add zero-resettable hand wheels; like those found on the MicroLux 7x16 mini-lathe: MicroLux Mini-Lathe
Thanks...
Chipper5783
Sep 25, 2014
748
Are you sure that the HF offering doesn't already have a graduated collar on the hand wheel that can be reset? Most lathes do have this feature (it would be so common, that most vendors may not even mention it).
rfresh747
New Member
Dec 16, 2017
25
I'm not sure. I read the Manual (PDF) and could not find anything in it mentioning this feature. If it has it, I can't find it in the manual.
mikey
Dec 20, 2012
4,779
I took a look at the manual and the IPB shows that there is a separate indexed collar. This is almost certainly a zero-set collar.
Tom beat me to it. The collar I referred to above is part 87.
[6]
[5] [7]
