Mini Mill owners check this out
I wish, I have a sherline and I do not have a way to mount it, but maybe could build a swing arm to put it in the rite position.
How bright is it.
KVT
Any pics of it mounted? Or is that what your having a hard time posting?
here are some photos of it mounted and I have a very hard time finding how to post from the home page.
If you have a mini mill these lights sell for $53.00 at 24.95 its a steal Head up flash on.jpghead up no flash.jpgNew Mill light.jpg
Hope this helps.
Regards
dgehricke
What is the diameter of the hole? I have an X2 variant but I also have a drill press that could use a light.
these are the dimensions as posted on the web site
[h=2]Product Details[/h]
  • Product Dimensions: 7.1 x 5.9 x 3.9 inches
  • Shipping Weight: 7.2 ounces (View shipping rates and policies)
  • ASIN: B00FDMSREQ
  • I would assume the 3.9 inch is the diameter it should fit yours easily.
Regards
dgehricke
I measured this today while I was making an adapter for mounting on the mill. My light measured out at 2.502 " inside diameter.
I started with a 1.102 thick piece of 4" dia 6061 Alum. I put 2 colors of dykem one side for the mill and the other for the light here are some photos,The work only took about 3 hrs.
Adapter for LED light.JPGCut a 4" disk x1.102.JPGCutting Dia. for light.JPGCutting the Dia for Mill.JPGDouble Dia. 1 for mill 1 for light.JPGThis is why I used 2 colors of dykem.JPGNice fit in the light dia & depth.JPGThis side for lamp.JPGThis side to bottom of Mini Mill.JPG
will post photos of the finished product tomorrow.
Regards
dgehricke
Adapter for LED light.JPG Cut a 4" disk x1.102.JPG Cutting Dia. for light.JPG Cutting the Dia for Mill.JPG Double Dia. 1 for mill 1 for light.JPG This is why I used 2 colors of dykem.JPG Nice fit in the light dia & depth.JPG This side for lamp.JPG This side to bottom of Mini Mill.JPG Bore it too size.JPG Test fit for the Mini mill.JPG
