[4]
Mini Mill R8 spindle
[3]
[10] Like what you see?
jrkorman
H-M Supporter - Gold Member
Jan 22, 2017
69
Likes
89
#1
Bought a HF mini mill a few days ago (lightly used), so got it home and have torn it down and am cleaning and
relubricating as I go. I've got to the spindle now and am noticing that the shank will go in about an inch or so
then is very hard to insert any further. When I was taking things apart it was a bit difficult getting the shank out
of the spindle.
So is this in the range of "normal?"
I've looked at the shank and it appears to be well finished, smooth with no burrs or such. When shining a flashlight
into the spindle bore it looks as if the surface finish is a bit rough!
I'm still cleaning other parts and probably going to wait until I get the belt drive kit before I do much with this machine.
Any suggestions on how to attack the problem would be appreciated.
Thanks,
middle.road
Actively Learning...
Apr 28, 2014
1,663
Likes
897
#2
Might need to see some picts on that....
jrkorman
Jan 22, 2017
69
Likes
89
#3
I'll see what I can do - lighting might be interesting
Think I may have found it. After looking at several pictures, I went back out and tried several more times.
I've noticed that it starts to "drag" about a 1/2" after the locking grove makes contact with the pin (upper left).
I ran my finger along the grove again (not the first) and noticed that there is a burr from there at least a couple
of inches. Still very tight, but guess I've more work with the file to do.
Putting a very light chamfer on the edge of the grove shouldn't cause any problems that I can see!
Redmech
Active Member
Jan 14, 2014
160
Likes
177
#4
Does the R-8 bore in the spindle have the small metal post that engages the R-8 collet? Is it lined up?
Be curious how rough the bore is.
jrkorman
Jan 22, 2017
69
Likes
89
#5
The post is fine and the shank inserts past that. Seems to be binding up as the straight portion of the shank gets further in. I cleaned up the grove and that has helped a bit. Feels like trying to insert a shaft into a very tight fit.
See the picture above.
higgite
General Manger - Proofreading Dept.
Aug 15, 2013
860
Likes
901
#6
Is there a way on that mill to adjust how far the alignment pin sticks out of the sidewall of the spindle? If so, you might try backing it out a hair and see if that helps.
Tom
Billh50
Jan 26, 2015
1,922
Likes
1,432
#8
Sometimes either the pin is rubbing because it sticks out too far. Or the groove in the collet is too narrow causing a binding. To find out if it is the pin or the collet I would try a couple collets. If they all bind a bit then it probably is the pin causing the problem.
chips&more
Mar 19, 2014
2,462
Likes
1,790
#9
I would take the pin out, so it is not in the way. And GENTLY with a brass fox tail brush (the correct size) and WD40. Clean out the hole. Then get back us…Dave
D
Deleted member 473
Guest - Please Register!
#10
Take the pin out and throw away!
mattthemuppet2
Sep 28, 2013
1,713
Likes
1,113
#11
sounds like your problem is the same as the one I have with my Grizzly mill - the part of the spindle where the end of the R8 collet ends up (bit closest to the threaded end) is ever so slightly undersize. Some collets go in ok and can get drawn up by the drawbar, others will do what you describe. nothing to do with the pin in the spindle. For my ER25 collet chuck I blued it up with Dykem and carefully knocked down any parts where the dykem was removed. Did that a few times until it would seat. One day I'll very carefully take a sand paper lap to that part of the spindle and see if I can open it up a tiny bit so that my other collets work.
kvt
Oct 21, 2014
2,024
Likes
1,007
#12
Mattthemuppet2, I was also going to suggest the Dykem or perm marker to tell where the problem is. I even had a couple of the R8 that had burs in the grove that rubbed a bit.
You need to see where the problems is before you start working on the spindle other than cleaning, I do see a small bit of light rust that could be cleaned with scotch bright and wd40 but does not look that bad. but take care of it now while searching for the problems before it gets worse.
jrkorman
Jan 22, 2017
69
Likes
89
#13
  • The pin and grove look good - nice clearance (especially since I got ride of the burr on the shank)
  • Cleaned the spindle bore and the shank very well and then applied a light oil to both.
  • Was able to get the shank in ok - with a little "juggling"
  • Once in good, I moved the shank in and out of the bore a few dozen times; that seemed to help.
  • Found a good spec on the R8 shank.
  • Then got out the telescoping gauge and micrometer and did some measurements as follows. (Mine in red)
  • I set the gauge starting at 0.955", which was loose, and started working my way down.
  • So it appears that the finished end (top of the bore) is just barely a slip fit
Thanks to all for the suggestions -
higgite
Aug 15, 2013
860
Likes
901
#14
I'm thinking you want to leave the spindle throat-to-collet fit fairly tight to be sure the drawbar pulls the collet straight up and doesn't cant it to the side while seating it in the spindle. The drawbar on my machine rattles around in the spindle when there is no collet attached and there is no way to really accurately center it. Without the close collet-to-spindle fit in the throat, it could cant the collet enough to affect tool runout.
You said it was difficult to get the shank out while you were taking the spindle apart. That is normal after it has been drawn up tight with the draw bar. Typically, you will have to tap on top of the drawbar to dislodge the collet after you loosen the drawbar.
Tom
jrkorman
Jan 22, 2017
69
Likes
89
#15
Tom
Thanks - That's why I was asking about the "range of normal!" I'll leave it alone.
On a positive note - I went out yesterday and checked the spindle runout (0.001" indicator) - outside and inside barely move the needle.
Put the R8 shaft in, with Jacob's chuck, 1/4 drill rod hardly any movement at all.
[6]
[5] [7]
