[4]
Modifying the dials on a mill/drill
[3]
[10] Like what you see?
mickri
Active Member
Oct 31, 2016
468
Likes
253
#1
On my Excel mill/drill the dials on the X and Y axis are locked to their shafts by pins and are not adjustable. The dials are long enough so that there is plenty of room to cut the dials to make them adjustable and put in a set screw to lock the now movable portion of the dial to the shaft. My concern is that dial will now be shorter in length by the width of the cut. It appears that the dial is designed to be a very close fit to the table to control run out. Think that I could make a precision washer to compensate for the width of the cut. I don't know if this would work or cause other problems.
The other thing that I could do is make a sleeve to fit over the existing dial. My problem with this is that I don't have a dividing head to accurately mark the sleeve.
Are there other solutions?
Looking for suggestions.
Chuck
ch2co
Grumpy Old Man
Jan 9, 2013
937
Likes
655
#2
How about using DRO's on each axis? There's quite a few "how to" instructions on this site and Youtube. I've added them to both my mini mill and lathe and never looked back. I forget that I even have any of those funny little round dial things things with the lines on them, they are rendered worthless with the direct readouts.
another Chuck
CHuck the grumpy old guy
mickri
Active Member
Oct 31, 2016
468
Likes
253
#3
Maybe I didn't look in the right places because the DRO's that I have seen for sale were prohibitively expensive. Where did you buy yours and what was the cost? I'm another grumpy old fart who joined the ranks of the independently poor (ie retired) a few years back. I have to watch my pennies and I budget for everything. And I don't want to dip into my savings.
That being said I would love to have a DRO and a power feed for that matter.
Chuck
ch2co
Grumpy Old Man
Jan 9, 2013
937
Likes
655
#4
My DRO's came with the lathe and minimill that I bought from a fellow that was essentially emptying out his garage shop. All of the units on the mill are hard mounted and the three on the lathe are snapped on magnetically which was necessary for clearance issues with different setups. Some on this forum have bought cheap digital calipers from Harbor Freight and modified them to fit drill presses, lathe compounds, and tailstock quills. Here's a couple of pictures of how some of my units are setup and a couple of shots from eBay of available units. You don't need the fancy readouts and super high resolution systems.
Screen Shot 2017-01-15 at 10.35.53 AM.jpg Screen Shot 2017-01-15 at 10.35.16 AM.jpg
mickri
Active Member
Oct 31, 2016
468
Likes
253
#5
Thanks Chuck
I'll do some searching for DIY DRO's.
Chuck
kwoodhands
Jan 22, 2014
159
Likes
55
#6
Thanks Chuck
Chuck
You can buy digital scales from Grizzly, I Imaging etc. relatively inexpensive. I paid about $30.00 for 12" scales and about $45.00 for 24" scales. They are accurate enough for home shop machinists. The scales read in millimeters, inches and fractions. Pick one with a push of a button. The readout display is mounted with either magnets on the back or a holder that's provided. The scales read to 4 places, eg. .0005 .
You can cut the slide bar to fit your machine if necessary. They technically not a DRO , but a Digital scale.
I buy my scales from LA shop, they have a website.
mike
[6]
[5] [7]
