Here is a picture of what I have made so far. the bottom rail block had some slicer issues. I was planning on trying to use 8mm linear rail slides but I actually think I can get away without any linear slides. The other axis's are 1/2 drill rod. I've built in split cotters into the collet holder block though i'm not sure if they are the right thing for plastic.
I suppose it would be great if folks could help out with the design. Every joint on the quorn design is a lever and it will all add up to floppy if it isn't designed right. That said it feels fairly good. If it can take light cuts it is a win.
I think it is something that could be cast with lost PLA casting.
