- Dec 19, 2018
- 176
I just cracked open this motor that is spinning my "new" diy mill nearing the build finish line. It's what was on hand so I used it to cut the slots, etc. to power the mill. What are your thoughts on cleaning it up and using it until I can score a 1 or 1/2 hp motor to spin the ER20 spindle? Check out the nameplate. Packard/GM . It's a dual speed 1140/1725 washing machine motor rated at 1/3 hp, but it shows 6.8 amps or 816 watts on the nameplate which I always thought was about 1/2 hp. Also, it has bronze bushings with felt reservoirs instead of ball bearings, and is starting to squeal. Is this a deal killer? What are your thoughts on this motor?
