Motor losing power?
Cobra
Apr 24, 2013
707
I have a Grizzly G0750G lathe and lately the motor is losing power.
Any idea what could be the cause?
macardoso
H-M Supporter - Silver Member
Mar 26, 2018
1,210
Looks to me like a 2 HP, 220V, single-phase, 8.5 Amps, 60 Hz, 1725 RPM motor.
First check your connections are tight and utility power is in spec. I've been in a house where the voltage was 30% low for 2 months before they fixed the transformer on the tower.
Next check all the shafts, bearings, etc. to see if anything is binding up and robbing you of tool power.
Finally it could be a failing motor or motor capacitor, but that is unlikely.
How did you come to the conclusion you are losing power? Tool cutting poorly? Could this be a dull tool or mystery metal issue?
Cobra
Apr 24, 2013
707
Losing power because even unloaded, it will no longer spin up at the high rpm settings.
i have had problems with the starting cap. Could this be the running cap?
dpb
H-M Supporter - Gold Member
Oct 8, 2016
186
Check your belts. Motor might be fine, but belts are slipping.
Cobra
Apr 24, 2013
707
Belts are OK. At moderate rpm (360) you can hear the motor slow with anything over about .010" depth of cut.
Tinker2
Nov 24, 2018
18
Yes. It could be either or both capacitors [run/start caps [if installed]]. Easy to test w/capacitance tester. Inexpensive to replace. If you pull them, make sure to discharge them before touching the posts. They store very high current. Lots of info on the web about handling/testing capacitors.
Luc Duchesne
Oct 3, 2019
2
......Bonjour avez-vous l`information du moteur SVP , je peux vous aider !
Cobra
Apr 24, 2013
707
Thanks Luc.
It is a 2HP capacitor inductive motor.
It has a starting capacitor and run capacitor.
There is a centrifugal switch to take the starting capacitor out of the circuit.
The motor starts without issue but will not operate the lathe at 1400 rpm but will run the lower speeds.
Even at some lower speeds the motor will slow down with anything over a very light cut.
This afternoon I took it out of the lathe and had a look.
The run capacitor appears to be OK and the start cap looks bad.
The centrifugal switch looks clean and functional.
Jim
mksj
Jun 12, 2014
2,638
I have replaced the capacitors for others on a number of grizzly motors, also a number of individuals with PM-1236 motors. In addition to those that show obvious swelling or blown up, you cannot tell the function of the capacitor by looking at it, you need to remove it and test it with a LCR meter to look at things like capacitance, ESR and leakage. The specs are also different based on the type/construction of capacitors. I have a Sencore LC103 which tests the capacitors at their rated voltages, it is surprising how many new capacitors sold on eBay test poorly from sitting on the shelf for many years.
The start capacitors are electrolytic and can quickly overheat with frequent start/stops, and also go with age. Often with bulging. leaking or catastrophic failure. The manual specs the start capacitor as 150uF 250VAC. The run capacitors are usually film type and are more durable, the spec. on this lathe is 20uF 450VAC. You might consider replacing both.
Tozguy
Feb 15, 2013
2,415
I second mkjs' suggestion to replace both capacitors. A weak cap can cause problems with power way beyond what they cost to replace. Caps are consumables, not worth tolerating a suspect one.
WalterC
Jul 3, 2015
121
3rd on replacing both. Since they are cheap- buy a spare.
Tim9
H-M Platinum Supporter
Oct 11, 2015
708
Replace both capacitors and make sure you can hear the starting circuit switching to the run circuit. I have a big old snap on pedestal grinder. The start switch was stuck and it wouldn’t kick out to run. Those windings then quickly overheat and it too would then slow down. I’m amazed it never burned up on me because I was using it like that for a while.
FWIW...I think they make electronic starting switches now which are supposed to be the bees knees. Never used them. Just remember reading about them when fixing my grinder. I was able to repair my switch on my grinder.
AdBlock Detected
I've Disabled AdBlock
