- Sep 28, 2011
- 46
Doing this custom build on a old Goldwing 1975. Putting a 2006 Hayabusa inverted forks on, with brakes and wheel. Putting a 2008 Goldwing single-sided swingarm on.
The forks are alittle shorter than stock so made some fork extensions. The swingarm casting from the GW is too large to mount to the 75 frame so are going to just use the GL1800 differential and make a tubular swingarm from DOM. Will need to make differential mounting plate and swingarm pivot.
Picture of the extensions and starting swingare machining.
