- Apr 16, 2019
- 745
This is my first post so just want to thank everyone here for such a great web site ! I bought my first lathe a few weeks ago , Chinese one that appears to be the Smithy AT300 but with no milling head , just a plate where the head would sit . Right now I have it sitting on a home made wooden bench that was used for a AMT wood lathe . I plan on putting together a steel one from some kind of electrical equipment , made from 2x2 angle , it has to be shortened in width to fit my very small basement shop , but it will still be 24" x 42" when done . Not sure how what I'll use for a top yet but I do have a large galv. pan that was sold as a drip pan under vehicles . I didn't see any mounting holes under the tailstock end so I would think neither at the headstock . The Smithy manual said you could use the carrying bars on each corner to hold it down , which I might do . Anyway the bottom of the lathe looks to be just cast , should I try some epoxy to smoothen it when mounting or semi hard plastic ? Open for suggestions , thanks Al
