Mounting trunions
You don't need RT or indexer, that's what the SQUARE wood blocks are for. The hole in the square blocks is centered. Make a saw cut on one side of the block, put a screw in it to squeeze it back together around the barrel.. Now you have a barrel centered in a box.
Clamp it directly to the table, and bolt down some stops on 2 sides to locate it after you flip it 180 degrees.
Ok, I get it now. I am a little slow. Brilliant method and perfect for my situation and available tools.
I used to make up barrel plugs when machining our Howizter barrels . We had the big lathes and mills that could handle such size . At home on smaller ones , once your bore is finished , locktite a bar into it and chuck it up . Use a tailstock center in the rear of it . You can also turn the OD with precision concentricity with this method .
