- Dec 27, 2012
- 348
Hi guys. I’ll be mounting a new DX6 to a new 12x54 manual milling machine table. I’m wondering what would best to put between the vise and table? Way oil, Boeshield T9, other oil. The table is big enough so the vise is not likely to be getting moved regularly. I do not have plans on using flood coolant but a Noga mister might be used at some point.
I plan on cleaning in the table and vise base then using a precision ground stone on both and then applying what is recommended between the two. Thanks in advance for the help.
