- Mar 5, 2012
- 314
It is time to get back to work you my mule (M274A5)
I am upgrading it. Removed the cable hand crank, installed a electric starter(12 volt) installed a GM self excite alternate and electric system.
removed the gas tank to change the fuel lines and install electric fuel pump and pre pump filter.
I started the project several years ago.
Today I moved it out and started with the fuel return line. I need a section of gas hose to plum in the filter and pump.
The pump is from my spare Hummer parts. The need less than 10 pressure. The carburetor does no base a float, a 1/8” return line instead and mechanic pump ( can be a itch to start at times) electric pump will take care of that.
