Multi Head Drill Press
rwm
Robert
Mar 25, 2013
4,614
Has anyone seen or used a multi head like this?
Looks mighty useful if it works well. Is this uncommon? Valuable?
Robert
Never seen that.
Can you tell if it's original/built-in, or an aftermarket attachment?
It resembles one of those adjustable heads to access screw at funny angles, but with many heads....
Thanks for posting it!
-brino
I found one on eBay. It's called the Quadrill so it's aftermarket. Pretty cool but I assume it would add to the slop in the quill and not as precise as chucking directly. Hopefully someone will chime in.
R
Like a turret lathe, on a drill press. Who'da thunk it?
I've never seen one but have seen the time when I could have used something like that to drill, counterbore, and tap multiple holes. What is the 4th head hidden behind the plastic guard?
you mean like this???
i got it a little over 2 months ago from member TAWP Tool and have not mounted it yet!
How much is it worth??? Should I buy the drill press? Asking $400.
R
i'd be the guy that'd come in around 300-350 for the unit ;),
just because you know that there is one or more issues with the machine in general.
if it sounds and runs really good 350, if not 300
