MX-210V (8X16) mini lathe tooling size questions
Reporter
Dec 28, 2019
8
Have a MX-210V mini lathe ordered and can't locate any info on what size tooling the mini uses. Will not be changing the tool holder and would like to order a 7 piece indexable tool cutting set. Need to order a knurling tool also.
Also: Do I need a "short" MT2 arbor chuck to work efficiently in the tailstock or will a standard length arbor work in the MX210V?
Thanks
Nutfarmer
Aug 2, 2019
834
I would start with high speed steel not insert carbide. On a small machine high speed steel is your friend. It's not hard to grind with a standard bench grinder. A good place to start is the article here on grinding a high speed steel bits. An inexpensive book that is available used is How To Run A Lathe by South Bend. It an older book but the basics are still the same. Many thanks too the members that put a lot of work into the lathe tool grinding article.
Reporter
Dec 28, 2019
8
Thanks for the info...I was hoping someone with a MX-210V (8x16) could answer my initial questions.
Ken from ontario
H-M Supporter - Silver Member
Dec 26, 2016
1,643
Is this set close to what you're looking for?
Just in case you decide on HSS :
As far as 2MT drill chuck goes you don't absolutely need a short arbor but often mini lathes can benefit from any short bits, drill bits, short arbors , etc. you won't regret having a short 2mt arbor chuck.
Weldingrod1
Oct 14, 2013
667
Might consider an ER collet chuck for drilling. I'm going to set up my FRC kids lathe with two of them. One each for 1/4-20 and 10-32 tsp drills. Much shorter than the huge keyless they have now!
Sent from my SM-G892A using Tapatalk
Weldingrod1
Oct 14, 2013
667
Oh, and mt2 center drill holders and some mt2 drills...
Reporter
Dec 28, 2019
8
Thanks guys...for addressing my questions. I have a LMS mini mill with R8 tooling. Also have a Rockwell 11X48 lathe with HSS tooling - but it's in an unheated area in my barn. The MX-210V will be in my heated shop next to the LMS mini mill and is suited for my small Winter projects.
GrumpyGrandpa
Mar 13, 2022
4
Thanks
I am a newbie with MX210V. I don't know what is considered a "short or standard" arbor but i did have an arbor that had a tang on it that I had to cut off. I have several others that I have gotten from eBay and Amazon and I don't remember any standard or short designation so I assume they are standard and they work fine. I ordered a MT1 center for the headstock and it was too long due to the fact that the spindle is not milled deep enough. I will have to cut that off. I hope this helps.
AdBlock Detected
I've Disabled AdBlock
