- Jul 5, 2014
- 2,759
I'm not sure if I overlooked flaws, I just assumed that the work that was done was done correctly. That's what I get for assuming.
Spot huh, I like that. Fits him perfectly. He's a chiropractor, he needs to stick to that.
Yes the harness will definitely be a challenge. I'm saving that wonderful task for later. I've got this idea to mount my alternator down low and the same with the power steering pump, so I'll have to rout the wires to the alternator to the new location. . Right now the alternator is mounted high on a truck accessory drive mount. I don't like where it's at even if the hood closed. I'm on a Nova forum and they told me you can't mount the alternator there. Well why can't I? They said the belt routing will be wrong. Who cares, as long as the alternator spins it will be just fine. Belts can be rerouted. I keep reminding them I'm a machinist with a machining center and various other machines at my disposal.. I think that last fact is lost on them. It is nice to be a hot rodder and machinist. I can dream it up as a hot rodder, and as a machinist make it happen.
My current focus is getting the old rear end out and replacing the spring bushings. To do this the front spring hangers have to be pulled out. And the nut plates all spun when I tried to get them out. So I need to carefully cut the head of the bolts out and see if I can make a new nut plate and slip in there somehow. Then I need to get the explorer disk brake setup on the axle and work out brake lines. I'm going braided lines. I can make those up myself. And I need to find a way to marry the GM brake cable to the ford ones. But doing things like this are challenges I enjoy solving.
Today unfortunately my work on the car stops for awhile. At 2pm today my wife goes in for hip replacement surgery. I don't know how much I'll be able to work on the car during my vacation. They say they will have her up and walking the same day, and possibly come home tomorrow. To me that is unbelievable.
This is how you conserve on cotter keys, cut it in half and use it twice.
