My DIY power drawbar for the PM 940 CNC VS. No air needed.
Thanks Rod,
I like your idea of the right angle cordless tool. The cordless drivers are nice and compact. Keeps it simple.
I don't have (or need) a cordless impact driver so I looked for alternatives rather than investing in a cordless system. I'm still working on wearing out the old 18v NiCad cordless tools left over from my construction business.
The corded driver was $23 shipped from fleabay so it was a no brainier to explore if it was feasible to use.
Jay,
You must be my brother from another mother. I had the same idea as what you did. I actually took an electric impact tool apart to see how it can work. Then I sold my Southbend lathe and gave up on the idea.
How is your high speed spindle upgrade coming along?
Rod in San Francisco
Jay,
I've been running the spindle for a while now. I like it a lot. It was well worth the time and cost. I'm only running to 6K max which has been enough for me. I'm only running 103 Hz max due to the lesser quality motor and VFD. I could get to 7K with a better motor/VFD. About the smallest cutter I use on that mill is 1/8". I run 1:2 and 2:1 on the pulley ratios which seems to be a good balance. 90% of the time I run on the high belt ratio and can get away with some low speed work. If I'm doing steel I will switch to the low speed. The bellevue washer/pneumatic cylinder drawbar system is not quite strong enough to hold a large end mill for heavy roughing in steel. I get tool pullout if I run too hard in steel. Not a problem in aluminum. I should have gone with a 4-stack cylinder vs the 3-stack. Darn things are expensive.
TomS recently converted his and is running to 9K. I'm not sure how that is working out. I believe he did a 1:2.5 / 2.5:1 pulley ratio. I'm curious how that will work out at the lower end of the high speed range as far as torque goes. May not be a problem with a good motor/VFD. I've stalled mine trying to run below 1K in the high range.
I searched high and low for a definitive answer to this when I was considering using a 220v gear motor. I mostly found the reply to be "torque until it is tight enough". Not helpful.
The torque specs for a 7/16-20 range from about 20 to 90 ft. lbs. depending on the grade of bolt. Somewhere in the middle is probably about right but there are other factors such as dry or lubricated threads etc. that will affect torque. There are a few electric DIY systems out there that are using voltage rise, degree of turn or mechanical stretch of the draw bar as the limiting factor but the electronics to make these work get beyond my knowledge base.
Air impact systems are limited by available or regulated air PSI. For the electric impact driver system it is "torque until it is tight enough". It doesn't take long to get a feel for what is enough just like tightening a drawbar by hand.
Jbolt,
Thank you! A very helpful starting point. I was contemplating using an arduino to control an electric motor. All kinds of possibilities but the method Rod used may be the easiest quiet solution.
Jake
