[4]
My Grizzly GO765
[3]
[10] Like what you see?
Sitting on Blocks Racing
Active Member
Dec 8, 2014
84
So i got my first metal lathe in the mail the past Monday...shipped fast. thought some would like to see what they get if they are looking at this lathe
Came double boxed with the inner box surrounded by blue insulation.
View of inside of box
Some movement in shipping but no apparent damage
Active Member
Dec 8, 2014
84
Despite being double boxed and with no apparent damage to either box there was a little damage to the chip pan. I emailed Grizzly Tues night and had a call within 24 hours and they are shipping me a new pan. i just need to send a picture. it's minor but i keep my tools forever and like to keep them in good shape.
I also paid for lift gate service due to occasional back issues. The truck driver pretty much just handed me the box...I mentioned this in my email to Grizzly service and they said that was their mistake. the didn't make a not to the shipping company. So needless to say Grizzly was more than willing to refund my money for the service not used.
It came with a light coat of rust prohibitor and after a couple hours of dis-assembly and cleaning with WD40 she was good to go. I will say it came with all the gibs well adjusted and no slop in any of the components. Probably could have just started turning parts.
Here's the part that come with the lathe
Active Member
Dec 8, 2014
84
Few additional comments:
-The manual is really nice (1/4" thick) and explains the break in and operation of the lathe well.
-There was garbage in the tool post lock down knob. I had to run a thread chaser down the hole to free it up.
-The power feed direction knob is slightly off. Neutral isn't really neutral but I'm going to play with that a little.
I don't have a live center or center drills so I couldn't do much but I did run a couple of passes on a short aluminum bar and it seems to cut/face really nice when compared to the HF machine I borrowed from a friend.
Grizzly customer service has been great so far...lady even asked if I hurt my back or not. 8)
More updates to come after my live center comes tomorrow....if people are interested
mattthemuppet2
H-M Supporter - Gold Member
Sep 28, 2013
1,746
you know, I'm really rather impressed by the look of that lathe. I didn't realise you could get a mini-lathe with a reversible leadscrew (so you can thread out from a bore with the threading tool upside down) and cam lock tailstock. Is the hi-lo range a true back gear? The swing to bed length also looks in good proportion too.
It'll be interesting to see how you get on with it and your impressions after you've used it some.
Active Member
Dec 8, 2014
84
I'm not sure what you mean by true back gear?
The cam lock tail stock is pretty nice. I'm going to put a longer lever on it cause the access is a little auckward.
The box is labled 7x16 which is funny. I think if I got a normal bolt-style locking tailstock, it would turn a 16" part.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,509
Congrats on the lathe!
It's kinda stupid really, but many who knock these little lathes have never worked on one. :dunno:
I had the Micro Mark 7x16 which is basically the same machine without the two speed head and did some rather impressive (if I say so myself)work on the little guy. You do have to get a little creative sometimes on larger parts, but I enjoyed the challenge. Have fun with that thing. :))
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,448
Congrats! The 7x lathes are very capable especially for their size. If they weren't they wouldn't be so popular & wouldn't have been around for so long. There are so many mods out there for mini lathes & some of the most creative lathe mods & created by mini lathe users.
Even though I have a 12x36 now, I still think about getting a 7x10 lathe so I can have a mobile lathe that I can take somewhere to use if needed.
mattthemuppet2
Sep 28, 2013
1,746
Not sure if it's the right term or not, but a change in spindle speed by changing the gearing between the motor and spindle, rather than changing the motor speed. A lot of older lathes do this by using the spindle pulley to turn a counter shaft which then turns the spindle. Lowers speed but increases torque.
What's the lowest spindle speed on your lathe?
Baithog
Florida Machinist Group Moderator
Feb 7, 2014
350
The Seig mini lathes have a two speed gear box in the head. No counter shaft or belts to mess with. The lowest speed on my old mini lathe was somewhere in the neighborhood of 15 rpm, but the torque at that speed is lacking and the controller tended to hunt a little. It really isn't meant to turn large diameter stuff any way.
Active Member
Dec 8, 2014
84
Low gear is about 15 or 20 rpm to about 900. High speed was a little over 2000. I think the high sides will increase as it breaks in. When I first turned it on during the break in procedure, top speed was about 840 in low.
I made a new tail stock lock handle and noticed some taper. The tail stock is a little high so I need to work on that.
I already have a 5" 3 jaw chuck to go with it. I need recommendation on a 4 jaw.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,509
Had the same problem with my tailstock. Instead of dealing with the v-way, I took a little off the upper/lower interface. :)
And FWIW, I had good luck with my 4-jaw that I bought from LMS.
Active Member
Dec 8, 2014
84
Got my 3" chuck bored out to 20mm the other day. Now I'm working on a hand wheel setup for the head stock for tapping/die cutting threads. I think I can also make a indexing setup out of it as well....
mattthemuppet2
Sep 28, 2013
1,746
nice work! On the tapping handle front, you may be able to repurpose an old bike's quill stem (for either 1" or 1 1/8OD steerers) as they have a neat sliding/ sloped plug on the bottom to hold the stem tight inside the steerer. Either that or a tapered plug with slit outer tube (deansphotographica.com had one, but I can't find it right now) would work.
Active Member
Dec 8, 2014
84
the bike neck is a good idea. I think I'm going to go with the slit tube with tapered plug cause there more machining to practice with. 8)
I did order a QCTP, boring bars, some HSS tool blanks and a parting blade from LMS today to get some more tooling going. Sold sold transmission part this week so have a little spending cash.
Active Member
Dec 8, 2014
84
Did some work last week to line up the tailstock after dial indicating the ram. Shimmed up the rear to bring it in line.
New tooling came in Friday from LMS! The replacement gears come in today ( they where shipped slower mail to save me a few bucks...nice but I wanted them quicker) so I JB welded the broken gear so it I could try out the new tools. The glued gear is still holding. 8)
So to try out the new tools, I made a carriage lock....open
Locked
Active Member
Dec 8, 2014
84
Made a new tool post locking knob. the Allen bolt was driving me crazy.
Bored out the bottom to set down over the aluminum sleeve to help center it.
Re-purposes one on the stock levers but I'll probably replace it. Finally ground my own HSS bit, cut really well, better than the HF one on Al. Need to try it on steel.
Active Member
Dec 8, 2014
84
Added a new Al handle to the QCTP, short one couldn't torque enough to keep it from rotating.
Made a new small pulley to slow my 12 Craftman bandsaw down some more for cutting metal. I've replace the motor with a treadmill motor already but it still had issues getting slow enough
Active Member
Dec 8, 2014
84
Wanted to create a hand wheel to use while tapping or using a die. Might use it for hand turning short threads as well. Had a wood disk laying around so I chuck it up to gauge what size the final one needs to be for leverage.
Back size view of the expanding section. Hole near the disk is for a pry rod to hold it still while tightening the expanding bolt.
Going to start on another expander to mount up a gear type indexing wheel setup. I turned this one a little lose in the bore where it expands so it doesn't sit as true as I want it for the indexing system.
Active Member
Dec 8, 2014
84
Been a while for updates.
Cleaned up the work area and started a rack for tooling.
Added a tailstock DRO from a harbour freight 4" caliper
Added a AccuRemote 6" DRO to the cross slide. This is the second revision. First one was made out of 1/8 AL and flexed too much. This is 3/16 AL and 1" Square 1/8" tubing.
Added a rubber gasket swarf cover to keep the DRO slide clean
coolidge
Dec 18, 2013
2,005
One could add a buffing wheel, sanding disk, interesting.
Active Member
Dec 8, 2014
84
Actually the buffing wheel is a good idea...might have to try that tonight.
I also made a indexing wheel arrangement based off others efforts on the internet....need to take some pictures of that.
jsh
Active Member
Apr 6, 2016
59
A very good post. Helped me a lot. Do you have any more updates?
Help me out gents, what is DRO?
Jeff
[6]
[5] [7]
